P3 - what was the longest distance(maximum range) you were able to fly?
33929 191 2015-5-5
k.kavelaars
I just make it to 3800 meters, thats more than i expected, still got good signal but i went nerveus to fligh so far, it olso have to come back you know? battery ad 55% and going in the red because the disdance is further than battery can deliver for the way back, so did it once just to see how far it can go, but not to recomended...
2015-8-3
k.kavelaars
Is it possible to overcome the max altitude of 500 meters? by chancing the software settings or is this something what is not possible by software chancing?
2015-8-3
rdteam55.dji
R&D Team
Jim.young04@gma Posted at 2015-5-6 05:18
i too would like to know how to increase range. I have flown 3 or 4 times never being able to surpas ...
Hi, Jim. There may be many interference such as WIFI  in populated areas. If you want to fly father, you should do as follows: 1) Make two antennas of RC parallel to each other and wide sides toward the drones; 2) Select a place with less interference; 3)Select a channel with low interference strength; 4) Make the drone line of sight.
Good luck.
2015-8-3
k.kavelaars
Does the PH3 have a CE/FCC mode like the PH2v+ ?
With windsurfer home made antenna,s i made it till 4300 meters without losing signal strengt, this is fine for me not trying to go further..
2015-8-27
konicekj
Flight distance : 57703 ft
Czechia
Hi,
My maximum is 5 km away. I suppose I can fly about 5.8 km.
2015-8-27
toddf.perkins
4.8 kilometers with the windsurfer. I'm wasn't sure if the person who started this thread wanted to know max distance stock only or not
2015-8-27
aerdt
I hate to be the party pooper for the guys in the UK, but it's not legal at all to fly that far.
https://www.caa.co.uk/default.aspx?catid=1995&pageid=16012
The aircraft must be kept within the visual line of sight (normally taken to be within 500 m horizontally and 400 ft vertically) of its remote pilot (i.e. the ‘person in charge’ of it). Operations beyond these distances must be approved by the CAA (the basic premise being for the operator to prove that he/she can do this safely).
2015-8-27
bernilukas This user has been deleted
2015-8-28
Noziroh
Flight distance : 279196 ft
Denmark
4.1 Km out I got chicken and turned back. Completly stock P3P + iPad Mini 2 Cel.
Clear day, no obstacles from top of a hill.
Had full bars on both RC and Video signal. Could have gone way further, will try on a less windy day.
Edit: If I fly from the backyard surrounded by trees and whatnot, I get 2.8-3.2 Km at 120-200 meters up.
2015-8-28
2015-8-28
2015-8-28
Noziroh
Denmark
I would also really like to know, where on the remote it says CE or FCC. Or if its an automated process done via the GPS location.
I live in EU, but find the range amazing.
2015-8-28
zacnarimanian
I flew 1.2 miles. And that was with a non-light bridge phantom 3 standard
2015-8-28
DanH
Flight distance : 315177 ft
4040 meters... got chicken and decided to come back as wind started blowing... of course in the wrong direction.
2015-8-28
SpunOne69
How are you getting this kind of range???  I've gotten to 1900 feet (not meters) and I start getting the "weak remote signal" warnings...4 KM??  that's AMAZING!!
2015-8-28
Chuck1906
Flight distance : 3574003 ft
tchavalas@panos Posted at 2015-5-6 10:24
You might check out these videos:
https://www.youtube.com/watch?v=TwJKC9ldfJs
Is this a stock Phantom 3 and RC with no modifications done to it that's allowing this to fly this far?
2015-8-28
rayrokni
Flight distance : 8139875 ft
gcmini Posted at 2015-5-6 04:29
Zero feet if you are using the iOS app.
-2 feet if using android
2015-8-28
rayrokni
so u have broken 2 laws already, add the im sure 500m altitude and ud have 3 out of 3. yeayyyy!!
2015-8-28
rayrokni
tchavalas@panos Posted at 2015-5-6 22:24
first one isnt a phantom3
2015-8-28
gongml
Flight distance : 595413 ft
Standing on a hill by the Atlantic Ocean, I was able to fly a P3 standard 1.8 Km into the water.  At this distance, I had to adjust the orientation of the RC to maintain connection with the drone.   I might be able to push it a bit further, but the GO app shows that the battery is low so I called it back.
2015-8-28
DanH
SpunOne69 Posted at 2015-8-28 19:00
How are you getting this kind of range???  I've gotten to 1900 feet (not meters) and I start getting ...
Hi,
The phantom was "stock" apart from an antenna booster I bought on Ebay
http://www.ebay.com/itm/2-4GHz-A ... hash=item2ee4b3be5c
2015-8-28
SpunOne69
Yeah...I ordered one of those, still waiting for it to get here!!
2015-8-29
kairkyo161
everyone go flag this guys videos https://www.youtube.com/channel/UCp_nbHMvJw-ZURPkTEvu4SQ, he keeps claiming to be using a phantom 3 when its some fixedcam POS
2015-8-29
gsp171
How far? Very far, 3+ miles with Itelite
2015-8-29
Joe Blow
Flight distance : 417149 ft
Tahoe_Ed Posted at 2015-5-5 20:52
Do you have the Android App?  If so then click on the video icon, says HD, and the image transmiss ...
Good infoTahoe_Ed.   Curious, since I don't see you respond much, what are your responsibilities for the forum, i.e., moderator, technical assistance, etc.?  Thanks.
2015-8-29
Tahoe_Ed
Flight distance : 2605 ft
Joe Blow Posted at 2015-8-29 17:02
Good infoTahoe_Ed.   Curious, since I don't see you respond much, what are your responsibilities f ...
I am the NA Forum Support Manager.  I post here and in other forums.  DJI-Dave is one of my direct reports.  I was a little silent last week because I spent most of my time in Meetings at DJI's Shenzhen Head Quarters.  I toured R&D and met the team leads for our products.  The goal was to improve communication between forum support and HQ.  The better to serve our users on the forums.  I typically average over 300 posts on DJI's Forum and yes I am also the Super Mod on this forum.
2015-8-29
Joe Blow
Ok Tahoe_Ed and thanks for responding.  Glad your working on and managing forum support.  Touring R&D at DJI's Shenzhen Head Quarter, now that must have been cool.  Any idea who will be representing DJI at the International Drone EXP in Los Angeles, Dec 10-11?
2015-8-30
mgtkilledkenny
Flight distance : 1155823 ft
I'm getting around 3400m with parabolics on?? Does this sound about correct
2015-8-31
Jkeller84
Flight distance : 396955 ft
I got 3 miles with my DBSmods kit installed. Could have gone farther but battery was the limiting factor. Also, a fun little app crash at 3 miles out that made me wet myself.
2015-9-1
SpunOne69
I got a windsurfer and tested it out...8000 ft out with fluid video and good signal strength...
2015-9-3
cdnstudman
Flight distance : 2700653 ft
I was able to go 3km from Halton Hills
2015-10-13
Othan1
In the desert, I got 9900 feet before I chickened out.  Stock unit; full connection the entire time.
2015-10-13
storm1000
I got my P3P out to 15,000 feet (just under 3 miles) one way on the Central Oregon Coast... paralleling the beach.  Still had solid signal all around... could have pressed further but didn't.  Plan to post the video soon as I can process it ;-)  Oh... and factory settings... no antennae enhancement of any kind
2015-10-18
eosbak
Norway
I'm not able to reply to the poll as I've never even made it to alternative 1... Max distance for me so far is 380m (alt 42m) with my P3 Advanced.
I actually had better range on my P2 V+. Made it to 550m with that one.
Usually it drops connection on both RC and video at about 280-300m.
It's purchased in the US, but used in Norway. Has been to DJI Europe due to the rangeproblem, but it didn't improve.
2016-1-9
ullhan84
Malaysia
Just bought a P3a, finally made it to 2553m at stock mode after a couple of trial, then the rth kicks in sadly. average distance is around 1200ish meter each flight though..... so yeah. (in Malaysia btw, semi urban area with hilly terrain, altitude 120m)
2016-3-22
Bhujang
Flight distance : 534587 ft
i take you mean one way? I get close to 4km but just cant quite push it there. Loose signal and she comes home ;)
2016-3-23
Strawberry
Flight distance : 15974544 ft
Two weeks ago I done 6,343 Metres stock battery with DBS Mods so nervous coming back. lol
2016-3-24
MrWho
Denmark
I made a test, some days ago. The goal where to reach 2,5 kilometers. If I would reach 2,5 kilometers, I would turn home no matter what.
Well it did reach 2,5 kilometers with ease and only lost one reception bar on my screen. Wi-fi channel was set to auto.
2016-3-24
moses the almos
Flight distance : 153766 ft
iv been a little over 2 miles with my ant mod, stopped at that got worried
2016-3-25
arock387
I think about 6200 ft is the furthest I have gone out before losing video signal
2016-3-25
