P3 - what was the longest distance(maximum range) you were able to fly?
33927 191 2015-5-5
CapitAn
Furthest l sent mine out was 12,000 feet (3.6 km). lt didn't lose any bars so could have gone further, no signal loss or lag at all. lt was flying against the wind but as soon as it hit 50% battery l brought it home anyway, just in case.
Don't judge the camera settings :p
2016-3-26
kcmusa
Flight distance : 132067 ft
lots of interference where i am, I did get 1.2km
2016-3-27
arock387
So today I finally beat my last distance record.  My first record was around 6200 ft.  Today off my parents back porch and in the most open direction I could find I went about 10,700ft!  so a little over two miles.  It felt so nice to finally have that feeling that I beat two miles.  Of course this was over a small amount of a city and some farmland so there were plenty of power lines underneath to cause some signal interference at about that point.  Still had strong RC connection though but I did not want to lose video signal so I hit the return to home.  On that note.  Is it bad to just use RTH as a feature.  Some people only hit it when they need it.  I usually hit it every time I go out a distance and just let the RTH fly it back for me for a nice steady recording.  The RTH height is set to about 380ft.
2016-3-27
DJI-Ken
Flight distance : 1515312 ft
Here is a AirShou screen capture of a 5000m flight. It has been edited for time. Note that when the Phantom reaches over 5000m the RTH point is well behind the the battery's remain capacity. This required returning in Sport mode. The craft did make it back but did not catch up to the RTH point until about 500m from the HP.
2016-3-27
rburke11
shayd93@gmail.c Posted at 2015-5-6 00:41
Stupid thread, DO NOT push the range/altitude limit of your drone, you WILL lose it.
Excellent contribution to this thread except for the fact that these things are made for long distance. Read through the forums and you will see that distance from home point has no relation to lost drones. A fall from 100' is the same if I'm 50' or 5000' from home point.
2016-3-27
Morph1
Banned
2016-3-27
evsjas
Flight distance : 1995479 ft
http://youtu.be/1PM6nc6KQRE
Phantom 3 pro 22862 feet round trip. I chickened out.
2016-3-29
kenzo
Flight distance : 94964 ft
4350 meters
CE mode nord italy :-)
2016-4-9
rich
Flight distance : 197680 ft
tchavalas@panos Posted at 2015-5-6 15:24
You might check out these videos:
https://www.youtube.com/watch?v=TwJKC9ldfJs
The first video isn't a phantom 3. It doesn't even fly smooth like a 3 and there's no rev start up like the P3 .
2016-4-10
jason.hackney
Flight distance : 1331749 ft
P3A stock went out 8,321 feet yesterday and still had perfect video and full bars but had to return against the wind so decided to turn around. Was out in the country no houses and launched from a high hill top so had clear LOS with no obstacles.
2016-4-10
asiangear
Flight distance : 11308691 ft
DJI Phantom 3 Pro
Suburban area.  ~3.4mi (18200ft).  Controlled from backyard.
Cheap Ebay Parabolic Antenna Reflectors over stock antennae.
2016-4-17
dkruseski
Flight distance : 791184 ft
2016-4-17
evsjas
http://youtu.be/SY7hp7jxcoY over 16,000 feet.
2016-4-21
AlaskanTides
Flight distance : 1032293 ft
Distance
Distance
2016-5-1
AlaskanTides
11,300 Feet and I still had full bars and no lag.  This is with a stock P3 Advanced with all the latest firmware and updates.
I could have went much farther,  However  I feel  that that over 2 miles is more then enough....
In the areas I fly both my inspire and P3 have no trouble getting well over the 2 mile mark.  Other then the geofence scare ....I  Think DJI builds a rock solid bird.
2016-5-1
vinojaya6
Indonesia
I can 1.3km with P3A, all in stock. No mod.
2016-5-1
vinojaya6
Indonesia
I can 1.3km, with p3a, all in stock.
2016-5-1
vinojaya6
Indonesia
shayd93@gmail.c Posted at 2015-5-6 11:41
Agreed, you right!
2016-5-2
ridd
Sweden
2,8 km over water, then I lost video feed and returned home
2016-5-2
Ricardo
Flight distance : 4356421 ft
I have a P3A and I could get around 2 miles with the windsurfer boosters. They work great, but I have an area where I couldn't get to unless I could travel a little farther, so I tried the Artek Blue-Proton antenna boosters. About $60 and yes you have to take the controller apart, but honestly no big deal just as long as you take your time. Took probably 20-30 minutes. No issues at all. WOW, these things are amazing. I have been 15,000 ft. with strong signal both video & controller. That's far enough for me and I took my pics and traveled back home with 30% power left. Wouldn't think you could go a whole lot farther without chance of running out of power. I flew same path as with the windsurfers, and have travelled this route now several times with same results, windsurfers  can't get me that far. The Artek gives better all around signal wherever I go over the stock or windsurfer ones. I like the fact I don't have to take anything off of the stock antennas....I just fold them down and they fit in my case perfectly. I did also do the channel hack, not sure if that really helped but I stay on channel 22 and don't have any problems. Of course like all of you mention, this route I am talking about is over the water, free of any obstructions, etc. I can't do that over the city, but 2-miles is not a problem.
2016-5-2
brucey791
Flight distance : 409675 ft
I've got a P3 Pro furthest I've flown is 6KM! 12326.6 meters return trip.
Its totally standard apart from DJI carbon blades.
2016-5-9
daveyo240
I have a p3 Advanced and I can easily get 2km on the beach strip in hamilton ont
2016-5-11
baronerosso
Flight distance : 1978228 ft
Little more then 3.000 mt.
still good RC signal and video transmittion
2016-5-12
Cessna172
Never been further than 1,500 FEET.    But 1,500 feet was easy and I'm sure it would easily have gone further.
But about 1,500feet  is as far as I can go and still make out the Phantom visually.....and I follow the FAA guidelines / regs.
2016-5-17
dkruseski
32,542 ft round trip.
http://healthydrones.com/main?share=lcMkLZ
2016-5-17
rustymichaud
jbrazda Posted at 2015-5-8 14:59
Just hit 13,500 ft. Thats 2.5 miles.
I second that 2.5 miles without antenna or battery mods
2016-5-17
Phantomski
Flight distance : 14869882 ft
shayd93@gmail.c Posted at 2015-5-5 22:41
Why? RTH works well, as long as you set it up right and plan your flight well. Also, keep an eye on the battery %...
2016-5-24
Phantomski
http://healthydrones.com/main?share=ocaaPM
I did not go all the way to signal loss... but signal was spotty a bit.. There is an airport in that direction, and also.. I never went that far, so I was a bit.. stressed ;) Waiting for it to comeback was quite unnerving.
I had some youngsters watch me fly, they were very excited to watch the tablet, once I put the radio on the ground, and we let the drone return home pretty much the whole 7000ft to autolanding! Kids are so amazed by this technology.. sort of as I am ;)
2016-5-24
Not A Speck Of
Flight distance : 666493 ft
My limit without mods is:
6977 M, 22,890ft, 4.3 miles
With inexpensive parabolic antenna signal extenders, I made it to:
7128 M, 23,285 ft, 4.4 miles
Why isn't the distance with the signal extenders longer? I chickened out because the battery indicator told me to return to home. Next time, I take better note of the headwinds and tailwinds.
In fact, both of those distances could have been larger, as with each I returned with plenty of battery power left.
Chris
2016-5-28
Phantomski
asiangear Posted at 2016-4-17 19:11
DJI Phantom 3 Pro
Cheap Ebay Paraboli ...
How did you get the overlay on the video? Some web app?
2016-5-29
gianpapadopoulo
Flight distance : 286900 ft
Greece
2016-5-30
endotherm
Flight distance : 503241 ft
Phantomski Posted at 2016-5-30 16:37
Google DASHWARE.
2016-5-30
Phantomski
thx, will check it out!
2016-5-30
Ryan Atfield
4400m no mods
2016-5-30
skipilot1
Flight distance : 1557398 ft
jbrazda Posted at 2015-5-8 23:50
My friend who also has one, hit 7500 ft this morning.  Still had a good signal, but it RTH because o ...
I have a P3P. My longest distance is 4000 meters. I probably could have gone a bit farther but I did not want to push it. Returned with 25% on the battery. Total distance flown was 8978 meters.
I was using a windsurfer antenna booster. I have not been able to repeat the distance yet. I think it had to do with the route used.
2016-6-2
skipilot1
Jkeller84 Posted at 2015-9-2 08:36
I got 3 miles with my DBSmods kit installed. Could have gone farther but battery was the limiting fa ...
I am wondering about these flat panel mods. My experience with wifi drones is that the flat panel is good for areas that do not have dense trees and hills. Flat panel signals do not have any curve.
With my wifi drones I first tried a panel antenna and it was useless unless I started off from a large open field. After some reading I tried a 5 twist helical antenna that improved things somewhat. I then tried a 3 1/2 twist helical and that helped a great deal.
2016-6-2
R&L Aerial
Flight distance : 298100 ft
I flew my phantom 3 over 9 miles, I was follow it on my Polaris ranger.
2016-6-10
oks4n4
Indonesia
I can fly more than 4500 meters stock, thats 9km in mileage.... p3p
2016-6-10
Blowin' free
Flight distance : 1932687 ft
5km distance
http://healthydrones.com/main?share=WhxSRg
2016-6-11
dkruseski
37,357 ft round trip.
18,605 ft out.
http://healthydrones.com/main?share=gjaMoz
2016-6-11
