mortenak.gmail
Flight distance : 394587 ft
Norway
DJI Susan Posted at 2018-3-15 00:51
Hi there, could you get the image transmission in the APP? Does the gimbal respond when you toggle the gimbal dial? Please help us confirm, thanks!
Also, please refer below and try to reset again to see whether it helps.
Turn off the RC, hold the C1+C2+record button+gimbal dial at the same time, then turn on the RC, connect the APP to refresh the firmware from Oversea Status.
Thank you for your answer. I have fixed the problem.
Since the remote had a faulty firmware nothing worked or responded. No contact with the drone, no reset command or anything worked. I read somewhere that you could disconnect the battery for 10 sec to hard reset the remote. So I opened it up, disconnected the battery and put it back together. When I started the remote again I got the option to install the firmware again, luckily.
From that on I was able to upgrade the P3 and all the batteries.
I am glad that worked, but there should have been a way to hard reset the device other than disconnecting the battery in the first place...
Thanks again for your answer. Hope this can be helpful for others as well. |
