No Red LED rear LED fast flashing yellow
1007 17 2018-3-14
Charliejspark
Flight distance : 286654 ft
On boot up Spark front LED flashes red briefly then nothing. Rear LED seems to go through boot sequence then sticks at fast flashing yellow even when connected to RC,
Have 'refreshed' using Assistant 2 but same happens.
What do i do?
2018-3-14
Bright Spark
Flight distance : 22129 ft
See manual  page 10.
2018-3-14
Charliejspark
Thanks but this is not the problem.  There is NO red front LED after boot up and the RC is connected - you can fly but the rear LED just fas flash all the time.
2018-3-14
RichJ53
Flight distance : 1837356 ft
Charliejspark Posted at 2018-3-14 10:38
Have you tried to do a relinking procedure with the remote?? Or refresh the FW using the DJI Assistant 2 software.
Rich
2018-3-14
DJI Elektra
Please provide me the screenshot of the image screen. What is the color of the indicator of your RC?
2018-3-14
Hddeuce
Flight distance : 128261 ft
Are you filming?  If you are filming video, the front LEDs turn off so they don't interfere with the video.
2018-3-15
Charliejspark
On my way back home from Scotland. Will send screen shots over weekend. Spark flies with RC nut no red LED and constant yellow flashing rear LEDs
2018-3-15
SigP320
Flight distance : 491555 ft
Change your firmware to an older version then re-install the current firmware using the DJI Assistant 2 application.  You should be good to go.
2018-3-16
Charliejspark
Very helpful. But I have only had the spark a week and flown maybe 1.5hours. I should not be having to do this.
2018-3-17
Charliejspark
DJI Elektra Posted at 2018-3-14 19:12
Elektra have done two small videos (6 and (MB)  but can not up load them.  What screen shot o you want?
The RC indicator is Green and the spark flies but does not obey all commands. The RED forward LED comes on briefly when booting but is OFF afterwards. The rear LEDs just keep flashing Yellow,
The Spark is only a week old and I have hardly had any flying time at all.
2018-3-17
Charliejspark
SigP320 Posted at 2018-3-16 15:18
OK in desperation tried that - but still no front REDs! Also tried re-calibrating everything!
Probably send it back and ask for a replacement!!
Charles
2018-3-17
Charliejspark
Think I have a)found the cause and b) fixed the damage.  Connecting the RC to mobile with OTG cable caused it. Factory reset and new upgrade solved it. Hopefully all now OK - will see tomorrow.
2018-3-17
A CW
Flight distance : 13926112 ft
Charliejspark Posted at 2018-3-17 13:23
Glad you've solved it!
2018-3-17
Kerr
Philippines
please make a video on how you did it.. I have the same problem too. How to Factory reset and new upgrade?
2018-3-18
Charliejspark
Kerr Posted at 2018-3-18 01:03
I used Assistant 2 which has a reset at the bottom of the software versions and then simply re-loaded latest version.  Whilst it has resolved the RED led issue I am still not convinced it has totally solved the problem and am nervous about having a 'fly-away' now.
2018-3-18
Charliejspark
A CW Posted at 2018-3-17 14:59
Having flown today not sure I have!! But maybe because it is too cold. Front LEDs flashing odd colours occasionally.
2018-3-18
A CW
Charliejspark Posted at 2018-3-18 04:12
I've just returned from 2 flights - cold isn't the word! I AM FREEZING LOL
2018-3-18
Kerr
Philippines
Already fixed mine... Thanks!!!
2018-3-18
