Menkromsen
Flight distance : 1335732 ft
Norway
Hi!
I have bought a new Phantom 4 Pro.
When you go into the transmission setting in DJ Go 4 - and select 5.8Ghz the bars showing all the channels does not show anything. Is this normal?
When I select 2.4Ghz I can see the bars go up and down showing interference on the channels. When I select 5.8Ghz I can see interference on all the channels for a brief second, before they all go down to zero.
Been flying the Phantom bird for some flights and I also seem to get much less range than on my Mavic Pro. Been trying both 2.4Ghz and 5.8Ghz. I know that Occusync is suppose to be better - but I didn't know Lightbridge was this bad! I get a lot of screen tearing and lots of no video-signal/remote signal and the bird go into RTH.
The range seems to be around 1km and sometimes more. I live in Norway by the way, so only CE (crappy) mode here unfortunately...
(The Mavic Pro can easily go to around 3km. in open areas)
Is the 5.8Ghz band broken on my drone/controller? Or is is normal that you don't see any interference on this band?
I've checked at home in my apartment in Oslo, so there should be lots of interference -even on 5.8Ghz :-)
The drone is on the newly released fimware and I use the latest DJI Go 4 app on iOS.
