Osmo Mobile 1 Base fit 2?
1910 7 2018-3-14
WillBapta
Does the base for the DJI Osmo Mobile 1 fit the Osmo Mobile 2?
2018-3-14
BobWinNV
Flight distance : 284209 ft
No it does not
2018-3-14
DJI-Mark
Here is a solution you may consider: Most Osmo accessories are not compatible with the Osmo Mobile 2. However, Osmo Tripod is compatible with the Osmo Mobile 2 and can be mounted to it via a newly installed mounting hole at the bottom of the gimbal.
2018-3-14
StanfordWebbie
Flight distance : 178018 ft
If you still use your Osmo Mobile1, I saw a great tutorial that said to put the device into the base BACKWARDS, and the base then actually holds the Osmo Mobile 1 more firmly.  It does for mine.
2018-3-14
Sorry that they are incompatible, we recommend to use its own Base: https://store.dji.com/product/osmo-mobile-2-base But it is out of stock now, if you are interested in it, please leave your email in the purchasing page and we will send you a notification as soon as we have the item in stock.
2018-3-14
benmaundvisuals
Yes, it will fit the 1 base! I have the Mobile 2 and use my OSMO 1 base.
2018-3-15
airboss
Flight distance : 332087 ft
benmaundvisuals Posted at 2018-3-15 19:44
Good to hear!
2018-3-16
RegDawg
Flight distance : 54091 ft
Debated but decided to get a mini tripod instead like the gorillapod or similar.  Can be used in different situations.
2018-3-19
