Matthew Dobrski
Flight distance : 1831050 ft
Recently released Precise Fly Safe Database update (01.00.01.09) is available and related message will pop-up stubbornly until we finally decide to perform updating. If you control your Inspire 2 or Matrice 200 with standard RC and whatever device, updating procedure should go smoothly. Not so with Cendence and CrystalSky monitor ... Pushing the Update button will download the file, but that's it. Data is not installed nor distributed among all involved parts of the system. Therefore the message will show up again next time ... Naturally official instructions are nowhere to find ... Luckily some smart pilots figured it out already. Here's how it works with Inspire 2/M200 and Cendence + CrystalSky set-up:
1. Disconnect CrystalSky from Cendence controller
2. Plug USB cable into drone and other (small) end into CrystalSky monitor. Attention: Matrice 200 has a slider switch, located next to USB socket (see picture). Left position is for connection with DJI Assistant software in computer, right position is for connection with device, CrystalSky in this case.
3. Turn On CS, then the drone, then Cendence.
4. Wait for this annoying message to pop-up again, start updating. You should see a progress bar at bottom going for few minutes.
5. Restart the system.
5. Check the About status, should display Fly Safe Database version 09.
That should do ...
