15matjan
Flight distance : 1158258 ft
fansc4ff2133 Posted at 2018-3-20 10:12
(mAh)*(V)/1000 = (Wh)
the power banks I use, are rated 40000mAh @3.7V, ... 148Wh or 50000mAh @3.7V ... 185Wh. See the links at the beginning of this thread
Yes, we know the formula.
What I'm pretty unsure is these devices can deliver the power you mention 148 and 185 Wh respectively...
You rate them at 3.7 V. Why not at a different tension as they can deliver up to 20V.
For instance in the specs of your 40.000 mAh model, it delivers a maximum 4,7A for 12 to 20V tension. This makes a maximum of 94 Wh which sounds more realistic to me...
I was unable to find nominated rated power in any of your links, it is true, that the more mAh, more power to deliver, but few manufacturers are enough fair to state also the nominated power which is the measure of the amount of energy the powerbank can store (and subsequently transfer), not the current it can deliver.
https://www.amazon.com/gp/produc ... e?ie=UTF8&psc=1 |
