RobertWSimpson
Flight distance : 927185 ft
Bluebouye Posted at 2018-3-15 14:51
Thanks for the tips. The videos are good. I should have probably said I’ve flown Quadcopters before, I’ve actually built a couple on open source platforms albeit a couple of years ago. I have flown manually and know with even the slightest breeze your ac will drift and I know how when panic sets in things get out of control quickly so I get why people who don’t have experience of flying ATTI mode would struggle to retain their ac in such a situation. However, I never owned a DJI product and am curious to know if the errors that people I see posting and subsequent flyaways are mainly pilot error from not performing calibrations after firmware updates, checking compass offsets or any other preflight checks etc.. I am not familiar with the Dji go app but I would imagine all relevant information can be viewed pre flight to determine if it is safe to fly. I am just curious to hear what routines people have who have been successfully flying a Spark for some time have,.
If you know how to fly a quad, you're miles ahead of the curve already.
A couple of other things to do before you fly:
1. make sure that you set the home point. The craft will do this automatically as long as you wait long enough to get a robust GPS signal before you go flying around. You don't have to stay on the ground, but you do need to stay in the area where you want the home point.
2. make doubly sure to set your RTH altitude. I've seen videos of sparks flying directly into stuff because the RTH altitude is set to 'current altitude' or too low. Make sure that you set it higher than the obstacles in the area so that if you do lose connection, your little guy flies OVER them, not THROUGH them.
3. Have fun. It sounds like you're ready! |
