DJI Thor
Flight distance : 13602 ft
Hi there, for the first question, you have your drone, RC and app connected properly, right? Is there any error code when trying to launch the drone? Please help to confirm if your RC is in Mode 2, when using the custom RC mode, users might not able to launch the drone via the combination stick command, if you are in beginner mode, the drone will also not take off when there is no GPS signal. If the cases above are not your situation, please provide me with the operating video. Or you can try to use the auto take off on the app.
For the second issue, what is the reaction of the WiFi or app when trying the connect the WiFi via your iPhone? Please try to reset the WiFi of the drone by long press the function button for about 9 seconds and connect again.
For the SD card, we're not able to confirm the compatibility of other types of SD cards. Therefore, we advise using the recommended SD cards which have been tested and verified and could ensure the full functions. Thank you for your support.
