Sync Flight Records Failed
3267 20 2018-3-15
fans2b8b0ab6
Flight distance : 734669 ft
I have tried several times to sync my flights and it goes through the process of syncing by percentages but when it is completed there is a "Sync Flight Records Failed" message that appears.  Syncing has never been a problem in the past only in the last few weeks.  I have tried reconnecting the wifi connection and that does not help.  How can I fix this problem?
2018-3-15
ALABAMA
Flight distance : 10442687 ft
Are you logged in on two different devices, like a phone and computer?
2018-3-15
fans2b8b0ab6
No only through the p4p+ DJI GO controller.
2018-3-15
ALABAMA
Sometimes it may change your total up even if it shows failed.   Check to see if your totals have gone up.
2018-3-15
DJI Susan
Hi there, just to verify, does the issue only appears in some flight records or all flight records? Could you tell us your DJI Account(the email address when you logged in DJI GO)? We'd like to check at our end as well.
Also, please kindly export the failed flight records and send to us for analysis, thanks!
/DJI/dji.pilot.pad/FlightRecord/SyncResult
2018-3-15
fans2b8b0ab6
DJI Susan Posted at 2018-3-15 18:44
The issue just started with my most recent flights.  Prior to that there were no problems in syncing flights.  Account email address is: hborchids@earthlink.net
2018-3-16
fans2b8b0ab6
fans2b8b0ab6 Posted at 2018-3-16 05:06
I am not sure how to export the files you requested.  I am assuming those files should be on the p4p+ controller sd card.  However, the only files on the card are Lost.DIR and Upgrade log.  How do I transfer the files from the internal memory of the controller to the sd card?
2018-3-16
fans2b8b0ab6
fans2b8b0ab6 Posted at 2018-3-16 08:34
While I do not know how the DJI GO syncing process works,  since it goes through the syncing process and reaches 100% and then the message that it failed comes up, it may be an issue with your server.  Just a thought.
2018-3-16
DJI Susan
fans2b8b0ab6 Posted at 2018-3-16 15:18
Received with thanks! Please refer the below and connect to the PC to see whether you can access the file.
a. Power on the controller and connect with PC.
b. Drag the screen and a bar will show up. Tap “USB connected” at the bottom and then “TURN ON USB STORAGE” on the screen.
c. You can find the file from here: DJI/dji.pilot.pad/FlightRecord/SyncResult.
2018-3-17
sky wombat
Flight distance : 1454078 ft
have you tried clearing out some of the older files? I had a similar problem and clearing worked for me.
2018-3-17
fans2b8b0ab6
DJI Susan Posted at 2018-3-17 01:54
How do attach the sync file?  When I try to attach it says does not support that file type.  I also assuming you would want an example file when the sync worked and also one when it did not.
2018-3-17
DJI Susan
fans2b8b0ab6 Posted at 2018-3-17 16:02
The file we need is the failed sync flight records. Please try to upload to Dropbox or Google Drive, and share us the link, I'll forward to our engineers for review.
2018-3-20
fans2b8b0ab6
DJI Susan Posted at 2018-3-20 04:50
In order to share the file via Google Drive I need an email address.
2018-3-20
DJI Susan
fans2b8b0ab6 Posted at 2018-3-20 06:10
Feel free to share us your link, we'll send a request to get the authorization.
2018-3-21
CanonMax
Flight distance : 8953215 ft
this can be resolved, but DJI has to do that on their servers... they will need you flight records (using Dropbox link) but it might take a long time
I had this problem for a few months, but at the end it was solved!!
2018-3-21
fans2b8b0ab6
DJI Susan Posted at 2018-3-21 01:50
Here is the link to the failed sync file:  https://drive.google.com/file/d/ ... tT/view?usp=sharing
2018-3-30
fans2b8b0ab6
fans2b8b0ab6 Posted at 2018-3-30 12:38
Here is the link to the failed sync file:  https://drive.google.com/file/d/1e_zbYBAH8O-7G3KrliaSjF1qafR2SvtT/view?usp=sharing
However there is nothing in this failed file.  Here is another one with something in the file:  https://drive.google.com/open?id ... EFu335kqPutj_qIxz5c
2018-3-30
fans2b8b0ab6
fans2b8b0ab6 Posted at 2018-3-30 12:42
However there is nothing in this failed file.  Here is another one with something in the file:  https://drive.google.com/open?id=18PrVrnm6fqli-EFu335kqPutj_qIxz5c
This sync file from 2/25/18 was the last one where it successfully synced:
https://drive.google.com/open?id ... SqAcT2n-iKG7t9U0xWn
2018-3-30
fans2b8b0ab6
fans2b8b0ab6 Posted at 2018-3-30 12:46
https://drive.google.com/open?id=1khAEMLrrtBFqZSqAcT2n-iKG7t9U0xWn
I completed several flights yesterday and now the syncing works.  Looks to me as a initial problem with syncing mechanism for the flight records from 3/12/18 which was resolved when syncing flight records from 3/31/18.  Basically, a brain fart of the remote p4p+ controller.  All flights have synced.
No further investigation necessary unless DJI wants to figure what caused the initial syncing problem.
2018-4-1
DJI Susan
fans2b8b0ab6 Posted at 2018-4-1 08:14
Received with thanks! I've forwarded to our engineers for analysis, will come back as long as there is an update.
2018-4-2
ddhruv
Flight distance : 538005 ft
Singapore
I am facing similar problem with my Syncing - its stuck at the 30% mark when i try to sync from my ipHone or from the I2 console
2019-8-11
