B1houdini
Flight distance : 927927 ft
Aardvark Posted at 2018-3-16 07:09
It is not an error (compass shown as 'normal'), it is simply a shortcut button to calibrate the compass if needed. The school of thought amongst most is that compass should only need calibrating when advised by system, or perhaps investigating any erratic flight behaviour.
In previous build this shortcut only appeared in the Aircraft Status listing IF system requested a calibration. For some reason DJI have changed their policy regarding compass calibration again in the latest manual for the Mavic Pro, which recommends calibration if over a certain distance from previous flight etc. The First manual, and the manuals for the P4, P4P, P4A & Inspire 2 recommended calibration only when system advised.
Aardvark Is right on his reply.
The only thing I would add is if there is a Calibration Error make sure you are not standing over anything that would cause a magnetic interference. I once stood over a Surveyors' medallion, got the error ,recalibrated a few times before I was smart enough to move off of the medallion. The medallion was covered over with the landing pad |
