Aardvark
Flight distance : 384432 ft
davidmartingraf Posted at 2018-3-16 12:25
Thanks Ian for providing the input. It's just that if you don't enable OA wouldn't it maybe interfere with RTH OA, if you go from not having it enabled to wanting it enabled in the event Fail/Safe RTH or Smart RTH, I just get nervous, even though having more speed and touch at the wheel makes for smoother flight, the sanity check knowing that if for some reason on the way home there's a path that the Mavic Pro needs to ascend before it can hover over and pass the obstacle, if the setting isn't enabled I just get nervous in the event you lost transmission connection on your phone so you don't know if there's an obstacle in the way or if the Mavic Pro is hovering until its battery is critically low in the event it will self-land, the dilemma is you don't know where the drone may be, and it likely is standing in front of an obstacle and didn't self raise itself because OA was enabled perhaps, and therefore the Mavic Pro was forced to hover until the battery fully drained, in which case it came down from the sky in a precarious position, possibly crashing or having some type of rough landing, most of all potentially in an area you have no idea where it is, at least if OA is constantly enabled you won't run the risk of this happening? This is just my primary concern why I don't disable OA.
Have a look at the visual navigations settings in DJI Go 4. You can disable Obstacle Avoidance, then if you look in the Advanced Settings in same menu. You will see that RTH Obstacle Check can still be enabled, which, as the note says :-
"When ambient light is sufficient, aircraft will automatically ascend to avoid obstacles. After enabling RTH Obstacle Check, even if obstacle avoidance is disabled, aircraft will still automatically check obstacles in RTH."
So you could have obstacle avoidance off and RTH 'Obstacle Check' still active to avoid objects on way home. |
