GoPro??
872 11 2018-3-16
fans21d46bf0
Will the Osmo Mobile 2 accomidate a GoPro?
GoPro hero5
2018-3-16
jmzyn
Flight distance : 102621 ft
Singapore
pretty sure u can except u would need an adaptor and that because of the wider angle camera, you would need to use the OSMO facing "backwards"
2018-3-18
RegDawg
Flight distance : 54091 ft
There are a variety of adapters you can get to be able to use a Gopro. Check on Amazon. There are also some youtube videos.
2018-3-19
DJI-Mark
No, that would not accommodate a Go Pro unless the company started making mobile devices. If you use any third party adapters, please consider the effects on warranty.
2018-3-19
LeChuck71
Flight distance : 68786 ft
DJI-Mark Posted at 2018-3-19 11:09
Sorry Mark, but what does an adapter has to do with warranty?
If so, is my phone case also an adapter?
The GoPro will work fine if it is properly attached to the gimbal - but you are lacking control, or use an additional phone
2018-3-19
DJI-Mark
LeChuck71 Posted at 2018-3-19 11:23
More on the warranty can be found here: https://www.dji.com/service/policy?site=brandsite&from=footer
2018-3-19
jmzyn
Singapore
cant blame DJI for pointing that out.
After all, GoPro was(and maybe still is) a direct competitor when it came out with the Karma & Grip.
2018-3-19
fans21d46bf0
Thanks everyone! I still am going to use the Osmo mobile 2 primarily for my iphone x! I can't wait to use it!! ;-)
2018-3-20
Mountaindrone
Flight distance : 26618251 ft
Finaly,
Somebody try to mount a Go Pro on Osmo mobile 2 ?
it's very interresting question !
2018-3-20
fans21d46bf0
Mountaindrone Posted at 2018-3-20 05:14
Finaly,
I haven't. I was only curious
2018-3-20
Mountaindrone
yes, I'm curious too
2018-3-20
Joemar7
American Samoa
I use a Gopro 6 with the OM2 with no adapter.  I found a great tip on youtube of someone using a bottle cap and a gopro, and others even have used an eraser to help mount the gopro on the clamp.  So there's no need to use an adapter.  With the OM2 you will need to turn the controls against you but it's doable.  I read the comment about using a gopro will void warranty and I don't see how.  I'm not questioning it and it's great they share their thoughts.  I'm not stressing the motors nor I am modifying it in anyway, except adding a bottle cap to make the gopro stick to the clamp.  The gopro weighs way less than my iphone 8 plus, it balances perfectly, and just sits on the clamp, and even other gimbal companies promote the use of a gopro with their gimbals.  Anyways proceed at your own risk, but I tell you I see no problem with mine.  If anything, DJI should promote the use of alternate ways to use other sports cams etc, for those people who are stuck using an iphone with OIS, which is a pain to deal with not to mention I use a gopro because the DJI Go app doesn't not give me 4k 60.  Anyways, good luck.
2018-3-20
