Geebax
fanse0081dfa Posted at 2018-3-18 05:34
Hi! thats what I thought, but it did record some videos but not all, in the cache of the controller I can seen all the videos. That is why I know that I was recording. What is weird is that the videos are not on the card but on the cache.
What is recorded in the cache is a reduced resolution copy of the feed from the aircraft to the RC unit. If you have it set up to record to the cache, then yes, it will always record there. The real file is the one on the SD card in the camera, and it is full resolution and does not have any transmission glitches. If your card is not always recording, try copying off any files you need and then format the card in the aircraft using the format function in camera settings.
