IMU Calibration will not start
12Next >
29792 43 2018-3-17
Rob S
Hi.
I have a new Mavic air.  It is showing a main controller error and says to run the IMU calibration. I have removed the propellers and have it on a flat service. I go to the Calibrate IMU screen and hit the start button and nothing happens.  I have the latest firmware updates.  Nothing seems to be wrong.  On startup the gimble goes through its motions, I just can't get the calibrate to do anything. Is there a hard reset or something that I should be doing?  I have removed the battery and put in a different one.  Still no love.
Thanks.
Rob.
2018-3-17
Rob S
I wanted to pass this along from the DJI guys here in Colorado.  They told me to put to the Air in the freezer for an hour.  I pulled the battery and in it went.  60 minutes later I pulled it, put in the battery, and reconnected and it sat there waiting to warm up.  Once it cleared that though my IMU issue was completely gone.  Not sure why this worked but thought I would pass it on in case it helps someone else.  Rob
2018-3-18
DJI Thor
Flight distance : 13602 ft
Rob, thank you for the update and glad that it came back to normal. However, I will still recommend that you try to calibrate the IMU once again. See if you can initiate the IMU calibration on the Main Controller Settings.
2018-3-18
Rob S
DJI Thor Posted at 2018-3-18 22:52
https://www.youtube.com/watch?v=x36WO2OnIaY&index=2&t=0s&list=PL8-vxWY64sBOeP6CJM0vmkDB0onco2V2i
Hi.
I did as you recommended this morning and the calibration process started up and finished no problem.  Thanks.
Rob
2018-3-19
davidmartingraf
Flight distance : 106566408 ft
You should try to calibrate your IMU using your PC?
2018-3-19
DJI Thor
Rob S Posted at 2018-3-19 08:56
Hi.
Good to know. Should you have any further questions, please feel free to contact us, we'd glad to help.
2018-4-7
DJI Thor
davidmartingraf Posted at 2018-3-19 09:01
IMU doesn't need to calibrate via the PC. But the vision system can be calibrated via DJI Assistant 2.
2018-4-7
davidmartingraf
DJI Thor Posted at 2018-4-7 03:08
That's what I meant of course the vision system. Thanks for clarifying.
2018-4-7
DJI Thor
davidmartingraf Posted at 2018-4-7 07:35
I sometimes mistype words, too.
2018-4-8
davidmartingraf
DJI Thor Posted at 2018-4-8 02:42
We're all human
2018-4-8
Enrique HK
Flight distance : 14278 ft
Thank you very much for this. Been trying to calibrate the IMU of my new Mavic Air and the problem was that as it is shown on the app DJI GO 4 theres no perspective to the image and it looked like the drone was flat on the ground instead of having to actually position the drone on all those different positions manually. This video is perfect and I successfully managed to calibrate.
Ready to fly!!! thanks!
2018-4-16
DJI Thor
Enrique HK Posted at 2018-4-16 23:05
Good to know that it helps you, Enrique. Enjoy your flight, btw, be cautious.
2018-4-18
Danny Berndt
I know this is an older forum but I just ran into this same issue... Spent hours on end trying to fix this issue... DJI assistant, DJI support, restoring older versions, reupdated versions, freezer, max battery etc! I was told to send it into DJI but I couldn't afford the week+ of not having my drone for work... Long story short this next solution actually worked... I smacked it with my palm a few times... and it actually worked... I had to calibrate the compass but once I smacked the drone a few times, the IMU wasn't acting up and I was good to go! Hope this helps lol
2018-7-30
HedgeTrimmer
Danny Berndt Posted at 2018-7-30 20:40
Smacking drone and it getting around IMU problem does not sound good.
Usually that means a bad connection.  Whether it be a connector, foil run, solder joint, or even a wire with a break.  Have seen small metal pieces (remnants of IC chip leg, solder flake) causing a short to open with vibration, only to come back later.  Thermal changes doing similar.
Do hope your IMU problem is permanently resolved.
2018-7-30
fans90868685
Guya i’m facing the same problem IMU calibration do not starts.
2018-10-12
fans90868685
fans90868685 Posted at 2018-10-12 18:25
Status indicates accelerometer failed and IMU Calibration do not start
2018-10-13
rust79
II also have problems with the IMU calibration. When I start my tello drone I get a sensor error. This does not indicate which sensor it is. When I then go to IMU calibration there is a red sign. If I try to calibrate then it does nothing. Have already tried to re-pair the battery, re-installed firmware and simply waited a few minutes when the drone was started up.
2018-10-23
Mavic Joey
I'm running into a similar issue. I select "start" on the calibrate IMU page and it does nothing. Any solutions?
2019-1-19
FidyRas
Madagascar
Having the same issue, can not start IMU calibration
2019-4-18
fans5e310c50
Belgium
Mavic Joey Posted at 1-19 10:26
Hi, have you found by any chance a solution for this problem?
2019-6-26
fansc37fde67
India
Hi,  I have a brand new Mavic Air,  however having some connection issues.  Getting a message saying Gimball cannot access main control data,  also showing a Gyroscope and IMU error.  Have tried to calliberate but nothing happens beyond the START screen.  Can someone help.  Thanks,  Indra
2019-7-21
fansc37fde67
India
fansc37fde67 Posted at 7-21 00:32
I have tried to restart the MA and the Remote Controller but nothing happens. Anyway will uninstall and reinstall the app as maybe some software issues.
2019-7-21
fansc37fde67
India
Is it possible to tag an admin for. Some quick help.
2019-7-21
fansf4ab1c54
fansc37fde67 Posted at 7-21 00:59
Did you figure it out? I have exactly the same problem. Clicking on Start doesn’t do anything, the IMU calibration doesn’t start.
2019-7-27
fans99f67f96
I’m also having the issue. Nothing seems to work.
2019-10-20
Diego P.
Argentina
Having the same issue, IMU calibration does not work. Anyone found a solution?
2019-11-15
Jordan Michael Fresh
I cannot believe it but after a full day of troubleshooting, freezer, ect., i smacked the ... outta her and she flies once more.. I appreciate the knowledge, wisdom, and experience, of everyone, i hope anyone else who is having a similar issue, finds a solution that works for them!
Happy Piloting eveyone!
Jordan Fresh
2019-12-23
fans8230b140
Jordan Michael Fresh Posted at 2019-12-23 08:41
Hello Jorda, Just wondering if you have any useful tip that I can use? I have the same issue and I can not do the downgrade since no versions are showing on my device.
thanks,
2020-1-17
Benjamien
Belgium
I'm having the exact same problems. Brand new drone (Mavic Mini) I select "start" on the calibrate IMU page and it does nothing. Any solutions?
(error messages: 40012, 30050, 30055) Can't this be fixed with an update, or at least a message in the app why the IMU doesn't start when hitting the start button.
2020-3-20
Benjamien
Belgium
Benjamien Posted at 3-20 03:09
On this thread https://forum.dji.com/forum.php?mod=viewthread&tid=208572 there was a suggestion to slap the drone while turned off. It worked for me. Unbelievable...
2020-3-20
djiuser_L5BN7ZkrNehg
Iceland
DJI Thor Posted at 2018-4-7 03:06
hola tengo el mismo problema, mi drone no pasa de 20% en  la calibracion Imu me sale un mensaje de temperatura siempre, estoy en islandia a temperatura -2 grados y adentro tengo unos 16 a 20 grados y en ningunas de las condiciones logro completarla aparte que tarda bastante en llegar al 20% casi 10 minutos a veces un poco menos, que puedo hacer?
2020-4-2
Iceland
Hi, I have a problem with my phantom 3 4k, I try to do the imu calibration and it always reaches 20% or less and it gives me a temperature error, I am in Iceland and I have -2 degrees and inside between 15 and 20 degrees and the same I always have the same problem.
2020-4-2
DJI Thor
djiuser_L5BN7ZkrNehg Posted at 4-2 13:32
Hi, please try to warm up the battery first, after startup the drone, please leave it for a while and then calibrate it.
The operation temperature of the drone is 0° to 40°C, it is not suggested flying when the environment temperature is lower than 0°C, thank you.
2020-4-3
Iceland
DJI Thor Posted at 4-3 00:49
I have found the problem, is that my drone has a problem with the firmware. since when the imu is calibrated it should not make any request and my drone always does DDDD-DDDD as if I was looking for or installing a firmware, so every time I try to put the firmware on the phantom 3 4k it gives me an error when it goes by 70% So if I open the drone camera but with an error in the firmware since I do not install 100%, what can I do?
2020-4-3
Iceland
2020-4-5
DJI Thor
djiuser_L5BN7ZkrNehg Posted at 4-3 05:12
I am sorry for the late reply. If the firmware was not updated successfully, you can try to connect the drone to the computer, format the SD card and check the firmware on the DJI GO app. If the firmware update available, it will prompt on the app. Then you can download and update the firmware. If the firmware update keeps failing, you may send in the drone for service.
Please fill out the online repair request on our official web and then send it back.
2020-4-9
Hamo
DJI Thor Posted at 4-9 23:14
Hi, I have tried to upgrade and confirmed that firmware from my mavic air is updated.
Unfortunately, DJI go 4 app is still showing Main Controller Data Error, and again nothing can be started even i clicked IMU Calibrate -> Calibrate IMU -> START
2020-4-10
Oneshotpk
Iceland
this its no the link
2020-4-10
DJI Thor
Hamo Posted at 4-10 04:27
Sorry, if refresh the latest firmware for the drone and restarting the drone didn't help, I'd suggest that you send the drone back to repair. If you are located in Hong Kong, you can book a swift service https://www.dji.com/service/repa ... dsite&from=nav.
2020-4-14
DJI Thor
Oneshotpk Posted at 4-10 04:33
I am sorry for the delay. You can go to https://repair.dji.com/repair/index?site=brandsite&from=nav directly.
2020-4-14
12Next >
