Different Serial Numbers on P4
1563 9 2018-3-19
Christian_T
Flight distance : 734442 ft
Hi there.
I just discovered, that I have different S/N on one bird, depending on where I look.
First of all, there is the S/N on the box and inside the battery compartment, which should be and thankfully are the same.
But then there is a different serial number in Airdata UAV, listed as "Internal Serial".  In the NoLimitDronez client I get a third number, called "Board SN".
So I have three different S/N which all start with "07" but then are totally different.
Anybody knows where that is coming from?
Cheers
Christian
2018-3-19
DJI Susan
Hey Christian, the SN on the box and battery compartment should be the same as they are the aircraft SN. The one you read on Airdata should be the SN of Flight Controller, you can check this in DJI GO 4>General Settings>About. Please let us know whether it is this case.
2018-3-19
Christian_T
DJI Susan Posted at 2018-3-19 04:20
Hey Susan.
Thanks for your reply.
The SN within Airdata indeed matches the one of the Flight Controller as it is shown in the GO4. So one mystery solved.
But still, why is there a third SN shown in the NLD client?
Regards
Christian
2018-3-19
DJI Susan
Christian_T Posted at 2018-3-19 04:31
Hey Susan.
The flight controller is an independent module, as well as the RC. With the SN, it will be helpful to check the exact status in the system.
2018-3-19
Christian_T
DJI Susan Posted at 2018-3-19 05:34
Yeah, I get that.
Yet, that still does not explain why there is a third SN, different from the one on the box / in the battery compartment and from the one in Airdata / GO4. It's also different from the RC serial number.
2018-3-19
MichealMedia
Flight distance : 179026 ft
They can tell whether you changed the flight controller from the SN
2018-3-20
Christian_T
MichealMedia Posted at 2018-3-20 23:52
Nothing has been changed on this bird.
Yet there are three different SN:
1. on the box / in the battery compartment = SN of the Phantom itself
2. as shown in Airdata UAV / GO4 = SN of the flight controller
3. as shown in NLD ('board serial') = ???
And the third SN is not the serial of the remote, as the remote SN start with "04" and not with "07" like all of those three mentioned above.
2018-3-21
Nebuchadnezzar
Flight distance : 3462946 ft
a curious case ..
2018-3-21
Christian_T
It is, indeed
2018-3-21
Christian_T
Nobody got an idea?
2018-3-27
