Can't link RC
711 17 2018-3-19
Alexander1962
Russia
Morning!
Can you help me?
Yesterday everything was OK, my P3S was good.
But today I power on and my RC solid red and drone flashed quikly and link buttom is solid red.
RC connected to iphone, DJI GO see it.
I tryed to link two ways - with DJI GO - start linking (beep-beep) - then pressed linking buttom (flashing red) and ... nothing, time out.
And second - round gimbal left and made S2 3 times - start linking (beep -beep) - then pressed linking buttom (flashing red) and ... nothing.
What can I do else???
2018-3-19
Rene Jensen
Denmark
try to relink the rc and ac without the app startet
2018-3-19
Alexander1962
Russia
Thanks for answer.
I tryed this way (with gimbal wheel and S2. RC in linking mode - press linking buttom on AC - it flashig red... and nothing.
2018-3-19
Rene Jensen
Denmark
its only resetting the wifi try to turn on rc and then ac and let it do its warm up and afer push the relink button on ac leg and hold it 5 sek and the release it to see if the rc light turns green
2018-3-19
Rene Jensen
Denmark
have you tryed to uninstall app and install it again??
2018-3-19
Alexander1962
Russia
I did:
resetting the wifi
  turn on rc
then ac
  its warm up
and the release it
to see if the rc light turns green - no, after hold it 5 seconds rc is solid red and ac flashing red :-(((
2018-3-19
Alexander1962
Russia
I will try now... I reset app and now I download it...
But ac and rc don't link without app!
2018-3-19
Alexander1962
Russia
In DJI GO I have:    App ver. 3.1.28
                                 Aircraft ver.1.70.90
It's OK???
2018-3-19
Alexander1962
Russia
I reinstall DJI GO, tryed to link, press red buttom on AC...and nothing, "Timed Out"...
2018-3-19
ALABAMA
Flight distance : 10442687 ft
Did you have a crash or maybe a hard landing the last time you flew?
2018-3-19
Rigger73
Flight distance : 378478 ft
Android tablet by any chance?
2018-3-19
Alexander1962
Russia
I had not any crashing.
It worked in evening in my home, and morning it died...
And I can't link rc and ac...
What else can i do???
2018-3-19
flyhigh69
Flight distance : 75079 ft
Alexander1962 Posted at 2018-3-19 12:24
huh, YOU did try the switch up and down with the camera roll down or up at the same  time? Seems like you tried everything else.  Good luck.
2018-3-19
Alexander1962
Russia
I switched S@ with the camera roll down - and I entered in linking mode on rc(sound), then ac(flashing red). And not connection...
2018-3-19
Alexander1962
Russia
My P3S without gimbal and camera.
Can I linking RC and AC???
2018-3-20
flyhigh69
Alexander1962 Posted at 2018-3-20 11:08
I read the drone would not work without the camera. But I might be wrong. But pretty sure the drone only will fire up and fly if the camera is working. Wait , are you saying with out the gimble and camera on the drone will it link.? I dont think so!
2018-3-20
Alexander1962
Russia
Thank you,
but it means that P3S not a drone, its only camera with props!!!!
Bad new!
Cost of camera the same the drone.
2018-3-20
Rene Jensen
Denmark
try to do a imu calibration thrue th app and leave the ac on a solid surface and dont touch anything while its calibrating.
2018-3-21
