fans27e733b1
AJD I2 Posted at 2019-7-22 19:30
And "Broadcast Mode" is an incorrect term. All it does is turn off the HDMI out from the Crystal Sky if you have it attached. You can choose manual channels for the picture, what Mbps you'd like to transmit from the craft to the Cendence, (higher Mbps, less range) and what resolution you'd like to output and either via HDMI or SDI.
I've done quite a few live broadcasts now, so feel free to ask any questions.
Hi Aaron,
I’ve completed a few live broadcasts. I’ve used an iPad and the HDMI in the back of the remote for the inspire two. Everything went well in HDMI 1080i. The last job I did, I was asked to pre-record and then upload it via the HDMI to the studio. With the iPad this wouldn’t work so I’ve bought a crystal sky. I’m hoping that with this having the SD in it, I will be able to playback the footage through the HDMI in 1080 interlaced to a studio next time. Do you think this is possible? Last time I tried to playback anything in broadcast mode it wouldn’t work. any advice would be amazing! |
