Nomad04
Flight distance : 55568 ft
[color=rgba(0, 0, 0, 0.870588)]After disassembling a mavic battery, I wondered if it was possible to change the battery to increase the flight time? The mavic battery is composed of three cells of 3.8 V to 3820 mAh per cell are connected in series, so the volt becomes 11.4 v "3.8x3 = 11.4v" while the amps remain the same because the connection is done with a series, to increase the flight time you have to increase the capacity in amps of the battery, looking on the net I found 4800 mAh lipo cells then 980 mAh more, this means an increase of 25; 7% of mAh which translated into minutes, keeping a 27-minute flight an increase of about 34 minutes. It is not so much as an increase but if it is feasible it would not be bad. then the price of three cells is 24 pounds, plus I also found slightly larger 5200 mAh cells but they should be in the dji mavic box. My question is the electronics of the battetia could fail by increasing the amps?
