My spark when you try and take off will not lift off and hover anymore, it will just sit on the ground and bounce up and Dow.
The joystick functions all work except the vertical lift and decent. Once you start it you can’t even stop it eg land..
First two times it did it I had to risk my fingers and pin it down to stop it. 3rd time I through s shirt on it.
I’ve tried to update firmware but it said its up to date and recalibrated the compass but still no joy.
Any suggestions or is it off to DJI?
Tried 4 times now with same outcome. Haven’t changed anything. The gimbal motor was stuck first time it did it with a grain of sand but even after I fixed that the same problem existed on the next flight. I assume it’s a hardware failure but just investigating if I missed anything
Lancehorton Posted at 2018-3-20 00:11
Hi, did you have video of the situation? If not, please export the flight data and the black box for analysis. You can upload it to dropbox and post the link here. Thanks for your support.
