Keule
Flight distance : 3733015 ft
After looking at your flight logs, i summarize the events as following:
There were no telemetry drops or timing gaps until the log stopped at 425,2 seconds.
I can not tell if you had video feed loss at that time.
In the final moments, no stick input (throttle, yaw, elevator, aileron) were recorded in the logs.
At 404,7s you stopped your gimbal down movement exact as seen in your second video.
At 409,9s the event 'AppAutoLanding' appeared.
That means, GO4 executed the command to land the aircraft. (@Gunship9 and @lomo2017 assumed already that the user pressed the 'land' button)
At 410,6s the aircraft started descending
At 425,2s log ends.
