iOS Pilot App v1.1.1 Flight Sim Bug
1863 10 2015-5-6
ei4jr
Flight distance : 1890640 ft
I wonder if this BUG is in the Phantom 3 section of the iOS app?
Im using the iPad Air 2 with the latest Inspire 1 Firmware v1.2.1.03 and latest iOS Version v1.1.1 App
2015-5-6
Abe
Flight distance : 524032 ft
Excellent - the range has been extended to accommodate intercontinental distances!
2015-5-6
Rockeyes
I hope that's not a reflection of what I can expect, when I go next to fly
2015-5-6
sbarryjackson
Flight distance : 18931532 ft
Abe Posted at 2015-5-6 22:02
If I fly to your house could you give mine a good cleaning and waxing?
2015-5-6
lucaoms
Flight distance : 599049 ft
have you set a new home point before fly?
2015-5-6
alexmarnas
Flight distance : 606237 ft
This is not new, we had that many times in the past with other firmwares.
Try to find a place where the inspire can get some GPS signal, restart everything, for me it worked.
2015-5-6
ei4jr
alexmarnas Posted at 2015-5-6 23:24
Try to find a place where  ...
Makes no difference at all. 15 GPS sat's. Marked home point loaded maps sadly none of them alter the small google map BUG.
2015-5-6
ei4jr
Rockeyes Posted at 2015-5-6 22:09
The craft works great with the upgrade no problems at all. Its just in the Flight Sim ONLY.
2015-5-6
Rockeyes
ei4jr@eircom.ne Posted at 2015-5-6 23:46
Thanks for that mate. I needed some good news
2015-5-6
DJI-Autumn
I suspect that your are indoors and there is no GPS signal and you didn't have WIFI connection because the GPS coordinate is (0,0).  (refer to your home point location...)
If you have WIFI connection the speed might be too slow. Click the restart button may help to solve it.
2015-5-6
ei4jr
DJI-Autumn Posted at 2015-5-7 15:39
I suspect that your are indoors and there is no GPS signal and you didn't have WIFI connection becau ...
Thank you for the reply.
The WiFi connection is good. Google maps load very quick when not in flight simulator I have  GPS satellites count of 15. I have used both the RC transmitter outside in my garden with 15 GPS Sat's and is still the same. I have been in different locations around my area and still the same.
I have had emails from other users saying that they are having the same problem. This did work 3 updates ago before 17 but has had this BUG in the last 3 updates.
2015-5-7
