Screw off lens cover
1812 16 2018-3-20
FlanniganFlyer
Flight distance : 1146473 ft
Hi all got my P3A back from repair service with a new camera and gimbal the screw off cover is impossible to remove to fit an nd filter, tried the elastic band thing but still no joy, any suggestions
2018-3-20
FlanniganFlyer
Was thinking would I little drop of penetrating oil do any harm
2018-3-20
Hellsgate
Flight distance : 1991555 ft
I wouldnt use any form of oil on it as it will possibly stain the outer surface.
2018-3-20
Hellsgate
You could try one of these its a rubber hose adapter.
Hold and brace the camera firmly then push the adapter against the lens and turn using only just enough force to do the job.
2018-3-20
DEUCEDOG
Flight distance : 2501575 ft
The trick is to grip the lens with the lightest of touch , the lens ring is very thin and distorts easily with pressure locking the fine thread even tighter  .
You may even find warming the lens bezel with your hand for a couple of minutes will help .
2018-3-20
FlanniganFlyer
Thanks guys for the oppositions i will most certainly try those and give you feedback thankyou
2018-3-20
RedHotPoker
Flight distance : 165105 ft
There was a trick using a piece of string, tied around the thin threaded end.
RedHotPoker
2018-3-20
DJI Thor
Flight distance : 13602 ft
Thanks for the suggestions, I think you can try, but please note to be cautious, don't break the lens cover.
2018-3-20
Dale 68
Flight distance : 338468 ft
I bought one of these recently and find it unscrews the lens easily
2018-3-21
FlanniganFlyer
Dale 68 Posted at 2018-3-21 06:41
[view_image]
Hi Dale 68, I had one of those sun shades in my drone case and it worked a treat thanks for you help, Hellsgate I must give a shout out to you for your suggestion, I would have tried your tool the hose connection but hadn’t one at hand, thanks to everyone that helped me with this issue, may you all have a great day
2018-3-21
RedHotPoker
That's awesome, thanks for reporting back what worked for you.
RedHotPoker
2018-3-22
DEUCEDOG
FlanniganFlyer Posted at 2018-3-21 13:08
Good result where did you get the lens shade ? i could use one of them myself  , summers on the way .... hopefully ?
2018-3-22
FlanniganFlyer
DEUCEDOG Posted at 2018-3-22 12:54
DEUCEDOG I bought treble pack of assorted attachments on amazon here’s the link, I have never used the lens sun shade, this is budget stuff so can’t tell you how it performs, only used the shade to get the lens cover off to put nd filter on https://www.amazon.co.uk/Anbee-P ... opter/dp/B015FI7ND8
2018-3-22
DEUCEDOG
FlanniganFlyer Posted at 2018-3-22 13:22
DEUCEDOG I bought treble pack of assorted attachments on amazon here’s the link, I have never used the lens sun shade, this is budget stuff so can’t tell you how it performs, only used the shade to get the lens cover off to put nd filter on https://www.amazon.co.uk/Anbee-Phantom-Professional-Advanced-Quadcopter/dp/B015FI7ND8
Thanks i will check it out
2018-3-22
Dale 68
Malta
Glad it worked for you, I found this out by accident
2018-3-22
Dale 68
Malta
I got mine off eBay for 99p from China
2018-3-22
DEUCEDOG
Dale 68 Posted at 2018-3-22 23:00
Thanks Dale it's on my wish list
2018-3-23
