Brian88
Flight distance : 385942 ft
Aperture, in this case, is used to properly expose the scene. As stated above histogram is your friend. Also, the overexposure stripes. Keep in mind depth of field changes with the aperture. Not drastically on the P4P but it does change. Also sharpness from edge to edge changes based on aperture settings. Every setting, Shutter speed, ISO, and Aperture have their benefits and drawbacks at each end of the spectrum. There isn't one setting for everything. Understanding how to balance the exposure triangle and achieve the desired effect is really what you are after. for instance, there may be a time where you need or want to break the shutter speed rule or bump the ISO up instead of opening the aperture. |
