Rustic17
Flight distance : 2733760 ft
I just ran across this JPG of flight controls and thought it might help some of the newbies in the forum. I flew fighters in the USAF so the control nomenclature is very similar...if you can remember a software program called Flight Simulator and ever flew any of the fighters, it's pretty much the same. In fighters (older ones, that is), you have throttles on the left and a stick between your legs (to the right of the throttles)...just like the Spark has left and right controls. In fighters, the stick controls pitch by pulling and pushing...it controls roll by moving left or right. Pitch is controlled with Spark's right stick/control by moving it forward and aft which actually moves the drone forward or aft (versus up or down like in fighters). Moving the Spark's right stick/control left or right is called roll which equates to sideways/lateral movement (unlike the fighter which actually rolls). Regarding Spark's left stick/control, moving forward and aft is called throttle movement and creates upward or downward movement of the drone (unlike in fighters where throttle movement is just adding or reducing power from the engine(s)). Think of the Spark throttle movement as increasing or decreasing power which increases or decreases lift...so the Spark goes up or down. Yaw in fighters is induced with rudder pedals which we don't have. In the case of the Spark, the left stick/control is moved left or right to get the drone to turn (yaw) left or right...rotating about the yaw/vertical axis of the drone. And these are the default controls in the Spark settings. You can modify them other ways, but these are the standards for most all drones I've flown. The diagram definitions are very helpful in trying to remember which control does what. |
