Connection reliability
464 9 2018-3-21
NedUK
Flight distance : 555262 ft
So getting the chance to use the drone more and more and finding that sometimes the connection reliability isn’t what I would expect.
Finding a lot of poor signal and no transmission signal warning messages.
Setup is
Spark
iPhoneX with a RTG cable
Any tips or advice would be greatly welcome!
2018-3-21
RjMllr
Flight distance : 17913 ft
Philippines
Fly in areas with less interference.  Rural area is an ideal one. Try not to fly on urban areas with tall buildings and congested people and houses. Keep in mind that WIFI and Radio signals can affect the connection between you and the bird. Always fly safe
2018-3-21
NedUK
Latest flight was Benidorm beach right in front of all the hotels, restraints.
Probably lots of WiFi hotspots, neon lights etc etc
2018-3-21
Ram-UK
Flight distance : 1132648 ft
Usually Spark is fine as log as you fly away from urban areas. I haven’t experienced much trouble WiFi connection. But it has a limit on the range. If you are in EU your maximum range will be 500m for 2.4GHz and 300m for 5.8GHz. Is your WiFi setting is in auto mode ?
2018-3-21
A CW
Flight distance : 13877205 ft
Rural areas with no obstructions between you and the drone.
2018-3-21
mattinhk
Flight distance : 54888 ft
Obviously Rural areas and less interference would be the ideal situation but last year I find it quite interesting that even in a very dense and populated city Hong Kong i never had much problem losing/weak connection (using OTG) but now im losing connection practically at 50m altitude/distance, and this wasn't the case until i did a firmware update
2018-3-21
DJI Elektra
NedUK Posted at 2018-3-21 13:47
I would recommend you fly in recommended environment and ensure that no bluetooth devices around your spark.
2018-3-21
NedUK
Ram-UK Posted at 2018-3-21 13:57
Ram-uk
Yeah it will be in auto I’m a bit of a new so any advice on the WiFi settings would be great
2018-3-22
Grant_Vorster
Flight distance : 394514 ft
South Africa
Check Wifi network on you Dji go app to see if network is flooded with wifi signals.  If all channels are red is probably best not to fly there.
2018-3-22
NedUK
Grant_Vorster Posted at 2018-3-22 01:26
I didn’t even know you could do this!
Every day is a school day at the moment
2018-3-23
