Auto tune fails
6230 10 2018-3-21
astropaulo
Fiji
I've been trying to use auto tune on my R2 and it fails every time. Running a large sony camera(XD). It is balanced. Auto tune bar makes it to about 95% then fails. What should I try to fix?
Thanks
2018-3-21
DJI-Mark
Ronin 2 is set for the following maximum payload: It supports a rated payload of 30 lbs (13.6 kg).  Please check to see if your camera is over that amount of weight. What type of camera do you have i.e. make and model?
2018-3-23
astropaulo
Fiji
DJI-Mark Posted at 2018-3-23 08:34
Camera is about 20 lbs and is a Sony PDWF800
2018-3-26
CineView Media
Flight distance : 5365522 ft
I bet you dont have the vertical bar on the cage tied down to your camera properly?
2018-4-15
astropaulo
Fiji
CineView Media Posted at 2018-4-15 01:40
I bet I do. Camera is rock solid in the cage.
2018-4-15
CineView Media
Norway
astropaulo Posted at 2018-4-15 02:49
Could you please post a couple of pics of your setup when its failing?
2018-4-15
astropaulo
Fiji
CineView Media Posted at 2018-4-15 04:09
I see you had auto tune issues also. I'll see if I can get a shot posted. I noticed DJI went quiet on this topic. Looks like you got some info in your posts.
2018-4-15
CineView Media
astropaulo Posted at 2018-4-15 13:11
Im pretty sure i can help you out, once i got a clearer view of your setup
2018-4-17
astropaulo
Fiji
Here's the rig
2018-4-17
astropaulo
Fiji
I guess you can't help and nothing from DJI.
2018-5-2
Justin Lovell0
Sent mine back for repair after all motors went limp and stopped responding.  They sent it back after 2 months that they had it, and now it is having the same issue you are describing.
Very frustrated with DJI service and support.  This is not PRO service that I expect from a gold standard company.
2018-12-9
