JJBspark
Flight distance : 12225059 ft
DJI Diana Posted at 2018-3-23 02:26
Hi there, normally, it is recommended to set the low battery default to 30% (actually, you can set it between 15% to 50% via DJI GO4 app), at this time, if the drone is far away out of your sight, then you need to fly it back until it in your sight. When the battery reaches 10% percentage, the drone will be forced to landing automatically and can not be canceled. Take good care of your drone and have a good time on flying.
In Forced landing mode you can still use the controls! even throttle up so use this if you are close home but above water.....craft will maintain height and fly fdw to get dry feet, as long as you have some power % left!
Cheers JJB |
