Lamplighter55
Flight distance : 538596 ft
As per subject line... does anyone know of a device that can do a multiband check on wireless 'interfernce/competing signals' at one's launch site - before flying the drone?
My flight today was interrupted by over 23 loss of data/disconnection signals. At the inital launch and checkout phase, the Mavic went up to the 6 meter hover (to set precision landing) and when I moved the Left/Up stick on the RC - nothing ... lost all stick control - then the Go4 App disconnected, but the RC was still showing control information (GPS etc.). Anyway after a number of further Go4 disconnects, while still in the hover mode - I rebooted the Crysalsky a few times and eventually a working connection was established. So I flew off a bit to see if the connection would hold - which it did on an off. Anyway seems I will need to go through a bunch of tests to try and findout why the constant disconnects and dodgy control even when the signal is at 5 bars. It would be good to know what is causing the bad signal dropouts, and a device that can indicate this other than the drone itself(!) would be useful.
The area I was flying is an open public heath (flat grass in all directions for 1km plus) in a Class D space - but well away from the nearest airport.
Here's a snapshot of the inflight notices (airdata site).
