fansceff17c6
Flight distance : 1834360 ft
Croatia
DJI-Mark Posted at 2018-3-23 07:47
Most likely, you will not be able to create a mission in which you can fly two orbits at different heights. Why not fly one mission at one height and then another mission at the other height and fix in the editing part of your videos?
DJI-Mark,
it's for 3D mapping and not for video.
Anyway, you did not read trough my post: if I set the min and max height to the same value, then the app gives me the error: Please set 2 or more points.
My 3 questions:
1. how do I create a cicular mission in GS PRO so that the drone flyes just one circle?
2. explain what is Min alt and what is Max alt? Give an example for using it.
3. explain what is Front and what is Side overlap? Give an example for using it. |
