3D Drones
Flight distance : 358917 ft
ING
Hello! I have a GL300A remote control of a P3P. Since a few days, USB does not work. DJI Go does not recognize the remote control with problems, but if it connects with other controls of model GL300A-B-C so I discard problems of the IPAD or the cable. Also change the back plate of the remote control, by another of the same model GL300A but it continues without connecting via USB. Is this due to a failure in the Motherboard? Is it a Firmware problem? (Google traslate )
ESP
Hola! Tengo un control remoto GL300A de un P3P. Desde hace unos dias no funciona el USB. DJI Go no reconoce el control remoto con problemas, pero si conecta con otros controles de modelo GL300A-B-C por lo que descarto problemas del IPAD o del cable. Tambien cambie ela placa trasera del control remoto, por otra del mismo modelo GL300A pero continua sin conectar via USB. Esto se debe a una falla en la Placa Madre? Es un problema de FirmWare?
