Sparkz71
Flight distance : 24259 ft
putduc Posted at 2018-5-20 08:57
Please I have problem that anyone have... I Have fly more combo, latest firmvere and etc.
PROBLEM: I conect phone with Remote with WiFi, evreting is ok, than when i turn off Spark, conection betven Phone and Remote brakes and i cant see anymore WiFi of the remote it doesn exist until i shotdown the Spark??
Hi. I had a similar problem. I could connect to the RC with DJI Go at 2.4 Ghz. As soon as I turned on Spark, DJI Go would disconnect from the RC.
Using a wifi analyser on my laptop I could see the 2.4 Ghz RC WiFi . Once Spark was turned on & connected to the RC, the 2.4 Ghz WiFi link from the RC to DJI Go disappeared. Very strange!
Note: Initially I used 'Floater' to force FCC Mode. That worked. Recently I also downloaded Red Waypoint but since removed the app as it was always running in the background & creating it's own directory... then DJI Go app would fight for control? I think using 3rd party apps with DJI Go installed causes problems.
I don't have any WiFi 'devices' to monitor 5.8 Ghz, so I don't know if I could re-connect at 5.8 Ghz with a capable device, nor can I use any WiFi analysers to check.
SOLUTION:
1) Pray
2) Remove DJI Go app & any 3rd party 'controller' apps from your device.
3) Reboot the DJI Go device (phone/tablet) & (re)install DJI Go.
4) Turn on the Remote Controller.
5) Hold the POWER button on the RC for 9 seconds - wait for the beeps, then release.
6a) Connect to the RC via DJI Go & select DOWNLOAD the oldest RC firmware.
6b) Press the 3 lines in the top right corner of DJI Go app & hold in place until the options change. Firmware downgrade options are displayed. Download & reboot RC.
7) Downgrade the Spark firmware via DJI Assistant or via DJI Go with a 'WiFi connection?. Reboot everything, reinstall DJI Go after deleting anything in the DJI folder.
7b) ...
8) Connect Spark via DJI Go directly (leave RC off).
9) Obtain firmware updates as suggested by the DJI Go app.
10) Reboot everything.
11) Connect to RC & apply updates.
12 ) Reboot.
13) Try the normal linking - Press 3 seconds on the Spark battery to enable linking & then press the 3 buttons on the remote or maybe via DJI Go. Otherwise press the power button for 9 seconds on Spark & remote - reboot & try again.
14) Hopefully everything works
I |
