Help - Mavic Air RC Windows driver required
29050 190 2018-3-24
DJI Thor
Flight distance : 13602 ft
MJKFLY Posted at 2018-7-5 12:36
Thank you  I was able to connect to the app
Good to know that, thanks for your feedback.
2018-7-14
KREMi
Poland
I will also ask for a win10 64bit driver, build new machine and it also got this problem :/
2018-7-14
Koori
Flight distance : 741 ft
It would be nice if DJI will release a new updated version on the main website, with all these hotfix.
Going thru forums to solve problems on this highly priced products its a bummer.
2018-7-14
DJI Thor
KREMi Posted at 2018-7-14 01:57
KREMi, I had PMed you, please check at your convenience, thanks.
2018-7-21
DJI Thor
Koori Posted at 2018-7-14 07:12
Hi Koori, I will forward this to the engineers. Sometimes it is because the driver is not mounted correctly. Hopefully, it will be sorted out soon without sending the driver.
2018-7-21
Wachtberger
Flight distance : 261509 ft
DJI Thor Posted at 2018-7-21 03:55
Dear Thor, would you kindly send me the download link for the latest driver version as well? Thank you very much!
2018-7-21
BeavistheLizard
Flight distance : 154 ft
Wachtberger Posted at 2018-7-21 04:58
My computer has stopped seeing the mavic Air. usb device unrecognised and I can not access the interna hdd footage trapped inside!
2018-7-22
Wachtberger
BeavistheLizard Posted at 2018-7-22 08:02
You better click "Reply" on the last post of Thor here above, this way he will notice your request.
2018-7-22
DJI Thor
Hi Wachtberger, I had PMed the link to you. See if you had received it.
2018-7-22
DJI Thor
Hi Beavis, if the drone is not recognized, please first check if you had downloaded the latest DJI Assistant 2 1.2.4 from the Mavic Air website: https://www.dji.com/mavic-air/info#downloads
If it is the latest version, you can check if the driver is installed properly, here's the tutorial for your reference: https://www.dropbox.com/s/1eawrb ... DJIAssist2.pdf?dl=0
Besides, you can also try to disable the digital signature. If the issue persists, you might need to try another PC for connecting. Hope it helps.
2018-7-22
Wachtberger
DJI Thor Posted at 2018-7-22 18:21
Thank you very much Thor!
2018-7-22
DJI Thor
Wachtberger Posted at 2018-7-22 21:45
You're welcome. Any further help needed, please don't hesitate to ask.
2018-7-25
DiversoP
Argentina
Can I get the driver too please?
2018-7-25
DiversoP
Argentina
Would be great
2018-7-25
小仙女的星巴克
Flight distance : 4657841 ft
I installed the drivers previously and no help....after I followed the instructions from the other thread now it's connected
2018-7-25
fansdb17f747
Wachtberger Posted at 2018-3-24 00:31
This is the one that was made available: https://drive.google.com/file/d/0B4jKLmmRYhQaX3pYOXJRWkpzSFE/view
I hope it will solve your problem!
Not working for me, keeps connecting / disconnecting
2018-8-17
fansdb17f747
SBasso Posted at 2018-5-15 00:25
Hello Thor,
Can you also PM the driver...as the very first one shared in this thread did not work for me.
Same problem to me, connect/disconnect cdc acm data driver windows 10
2018-8-17
fansdb17f747
DJI Thor Posted at 2018-5-16 23:18
Thank you for your feedback and glad to know the result. Any further issues, please don't hesitate to contact us, we are happy to help.
I need this driver cdc acm data driver windows 10 because I cannot connect! Thanks
windows 10 + assistant 1.2.3 + Mavic Air Remote Controll
2018-8-17
Wachtberger
fansdb17f747 Posted at 2018-8-17 14:22
I have just sent you a PM and hope it will work this time.
2018-8-17
fansdb17f747
Wachtberger Posted at 2018-8-17 14:31
Hi, thanks for sending me that. But you wrote: "take this one but make sure that your RC is connected to PC and switched on during installation". But how could I be sure that my RC is connected to my PC if the problem is exactly that I am NOT able to connect???
2018-8-17
fansdb17f747
Great!!!  Eventually I did it!!! I installed while RC and PC were on and linked by cable, then eventually I could see the RC in Assistant 2!!! Many thanks.
2018-8-17
forager3215
Flight distance : 230951 ft
DJI Thor Posted at 2018-7-25 04:25
RC won't connect to assistant 2 need driver as well i think TY
2018-8-17
Wachtberger
fansdb17f747 Posted at 2018-8-17 22:05
[view_image]
Glad to hear! :-)
2018-8-18
DJI Thor
fansdb17f747 Posted at 2018-8-17 14:26
Hi there, I noticed that Wachtberger had PMd you the link and you got it worked. Good to know that, thank you, Wachtberger.
2018-8-18
DJI Thor
forager3215 Posted at 2018-8-17 22:35
Hi there, PM sent, please check and see if it helps. Thanks.
2018-8-18
Wachtberger
DJI Thor Posted at 2018-8-18 02:50
You are very welcome Thor!
2018-8-18
Alan E
Flight distance : 6457 ft
DJI Thor Posted at 2018-8-18 02:51
Could I please get a link to the driver allowing the MA RC to connect with DJI assistant 2 on windows 10 64?
Thanks!
2018-8-26
Wachtberger
Alan E Posted at 2018-8-26 11:04
Thanks!
You have a PM.
2018-8-26
Alan E
Awesome. Thank you Wachtberger!
2018-8-26
Wachtberger
Alan E Posted at 2018-8-26 16:06
You are welcome, does it work now?
2018-8-26
saviour
Flight distance : 604203 ft
Wachtberger, for me too please. I want to test something.
2018-8-26
DJI Thor
Thanks!
Hi Alan, I guess that the issue is resolved as Wachtberger had sent the link, right?
2018-8-28
DJI Thor
saviour Posted at 2018-8-26 22:55
Hi Saviour, I had sent the link to you before, it is the same driver.
2018-8-28
cloud
Flight distance : 148245 ft
Indonesia
Hi DJI Thor,
Same problem with my MA's RC, could you help to send me (by PM) the link for driver?
Thanks,
2018-9-5
Wachtberger
cloud@rt.id Posted at 2018-9-5 08:00
Hi DJI Thor,
Thanks,
Hi, since in China it is already well past midnight now, I have sent you the PN.
2018-9-5
cloud
Indonesia
Wachtberger Posted at 2018-9-5 08:23
Hi Wachtberger ,
many thanks for the response and link..
will try tomorrow morning, hopefully it can works..
2018-9-5
Wachtberger
cloud@rt.id Posted at 2018-9-5 09:12
Hi Wachtberger ,
You are very welcome and please report back. But it should work out well I hope.
2018-9-5
NewMavicOwner
can you pm me also the latest windows 10 64 bit driver please.
2018-9-9
cloud
Indonesia
Wachtberger Posted at 2018-9-5 11:58
Hi Wachtcberger,
just want to inform, yes it can works now with MA RC,
Now 2 of them (RC and AC) can detect & connect with DJI Assistant.
2018-9-10
Wachtberger
cloud@rt.id Posted at 2018-9-10 23:14
Hi Wachtcberger,
Glad to hear this, thank you! :-)
2018-9-10
