Help - Mavic Air RC Windows driver required
29051 190 2018-3-24
Mcmarshall1989
Flight distance : 223353 ft
If there is not an official update on the Mavic Air and The Remote I will also need Windows 10 64 bit driver.
2018-9-17
Qi Yuan
Malaysia
any chances of sharing a working driver? I cant connect to rc, it keeps beeping. I'm running windows 10
2018-9-23
The_Tiger
@DJI Thor
Hi, I have the RC-PC issue connection on win7 64b.could you please PMed me the driver?
Thanks
2018-9-28
Sparky_87
Flight distance : 13645 ft
South Africa
DJI Thor Posted at 2018-5-21 22:58
Sure. Link sent via PM. Remember, connect the RC to the PC and keep the RC powering on when installing the driver. Then restart the DJI Assistant 2 and the RC and connect again. See if it helps.
Hi,
Can I have the Windows 10 driver for the Mavic Air RC as well?  I am using Assistant 2 v1.2.4 and still cannot connect.
Regards,
2018-10-13
DJI Thor
Flight distance : 13602 ft
Sparky_87 Posted at 2018-10-13 11:43
Hi,
Hi there, I've sent it via PM, please check.
2018-10-14
michalgizaaaaaa
Flight distance : 99813 ft
Poland
Hello,
can I ask for the Windows 10 driver for the Mavic Air RC as well?
Thanks
2018-10-30
weekpilotend
Flight distance : 388100 ft
I also need win 10 64bit driver
2018-10-31
EddieLin617
Flight distance : 310912 ft
Taiwan
DJI Thor Posted at 2018-10-14 21:08
Can I get the RC driver too please ? thx
2018-10-31
djiuser_N4jlCSy23HHI
Flight distance : 143832 ft
Russia
@DJI Thor
Thanks
2018-10-31
Ikbal Arafa
Flight distance : 1671316 ft
Tunisia
Hi
Can I have the driver?
Many thanks ;-)
2018-10-31
Chrisma95
Flight distance : 754501 ft
Hi I also need the driver please
Thank you in advance
2018-10-31
do-gugan
Flight distance : 24675 ft
Japan
Hello, I also need the driver to connect MA RC.
Thanks in advance.
2018-11-1
Xavier51
Flight distance : 529039 ft
Hello everybody,
I'd like to try the new DJI simulator but i can't connect my RC on my computer (Win 10 64bits).
It beeps like connecting / disconnecting.
Can you help me please ?
Thanks.
2018-11-1
WayneMHK
Flight distance : 694728 ft
5 months later and we STILL have to beg online for a driver?  This is insane.  Just post the damn thing!
2018-11-1
Nayeem
Flight distance : 56532 ft
India
Fixed it. Old drivers were not signed. I installed simulator software and found dji_usb_5512_64_108.exe drivers file after installing everything is fine
2018-11-1
Nayeem
India
Another method :
Follow step 1:
https://www.maketecheasier.com/i ... -drivers-windows10/
till you do this "Disable driver signature enforcement." when windows restart
1.connect rc to pc..
2. open device manager
3. right click on cdc acm and update driver > point to the old drivers folder
4. a pop up with warning of unsigned drivers will appear.. allow it
Done
2018-11-1
DJI Thor
michalgizaaaaaa Posted at 10-30 13:55
Hello,
Thanks
Hi Michal, I'd PMd you the link, please check. Thank you.
2018-11-1
DJI Thor
weekpilotend Posted at 10-31 01:07
Hi there, I had PMd you the details, please check.
2018-11-1
DJI Thor
EddieLin617 Posted at 10-31 05:49
Hi Eddie, please check your PMs, thank you.
2018-11-1
DJI Thor
djiuser_N4jlCSy23HHI Posted at 10-31 08:38
@DJI Thor
Thanks
Hi there, I've sent the links via PM, please check.
2018-11-1
DJI Thor
Ikbal Arafa Posted at 10-31 10:22
Hi
Many thanks ;-)
Hi Ikbal, link sent via message, please check. See if that helps.
2018-11-1
DJI Thor
Chrisma95 Posted at 10-31 13:56
Hi Chris, I had sent the details in PM, please try and see if that helps.
2018-11-1
DJI Thor
do-gugan Posted at 11-1 08:35
Thanks in advance.
Hi do-gugan, link sent via PM, please check.
2018-11-1
DJI Thor
Xavier51 Posted at 11-1 09:18
Hello everybody,
Hi Xavier, just to verify, was the RC recognized by the PC when you plugged it in? Please ensure that the RC is powered on and the connecting cable is working properly. If the PC has no reaction when the RC is connected, you may try a different connecting cable or try a different port.
If the RC can be recognized but the simulator has no reaction, please check if the driver of the RC is installed successfully, and see if the DJI Assistant 2 can recognize the RC. I will PM you the tutorial.
Please check if that helps.
2018-11-1
Ikbal Arafa
Tunisia
DJI Thor Posted at 11-1 19:48
Hi, Problem solved in my case. I reinstalled the driver.
https://forum.dji.com/forum.php? ... p;page=1#pid1631846
2018-11-2
DJI Thor
Ikbal Arafa Posted at 11-2 10:18
https://forum.dji.com/forum.php?mod=viewthread&tid=171054&page=1#pid1631846
Hi Ikbal, thanks for your update and it is great to know that your case is resolved. Any further questions, please kindly let us know.
2018-11-5
fanse49419dc
Flight distance : 19209 ft
Wachtberger Posted at 3-24 13:43
Good to hear! And does it still recognise the Air too? If not, just reinstall DJI Assistant and then both will work well.
I was able to get the driver installed, and now under device I do have DJI USB Virtual COM.  However it is still unrecognized in the dji assistant.  I tried to uninstall and install the assistant but no luck.
2018-11-28
paypi014
Philippines
Hi Mods,
My win 7 64bit laptop is able to detect my Mavic Air after letting windows look for a driver. But now I am connecting my RC to my laptop and it can't detect it. The DJI USB Virtual COM and CDC Abstract Control Model are the ones I could see with (!) on device manager. Could you please send me a driver for the RC?
2018-12-1
CriZUndercover
Flight distance : 71709 ft
DJI Thor Posted at 2018-11-1 19:50
Hi
Can I have the Windows 10 driver for the Mavic Air RC as well?  I am using Assistant 2 v1.2.4 and still cannot connect. thanks
The same issue on win 7-64 both driver would be perfect
2019-1-2
DJI Thor
CriZUndercover Posted at 1-2 08:04
Hi
Hello there, I had PMd you, please check, thank you.
2019-1-3
DJI Thor
paypi014 Posted at 2018-12-1 14:09
Hi Mods,
Hello there, sorry for the late reply. I had PMd you the link, please check if that helps. Thanks.
2019-1-3
CriZUndercover
DJI Thor Posted at 1-3 00:12
Hey, there is no prob with the RC driver, I cannot detect my aircraft on both systems
2019-1-3
DJI Thor
CriZUndercover Posted at 1-3 08:50
Thank you for the clarification, I had also replied to your PM, please kindly check, thank you.
2019-1-6
bib60
Hi
Can i have the driver too ?   ;-)
Thanks
2019-1-7
fans9d1476a2
Flight distance : 617 ft
@dji thor
I am in need of the driver for the Mavic air RC too... Windows 10, 64 bit.  I sent you a PM regarding this as well.
2019-1-7
bib60
Hi Everybody
I've tried something that's work perfectly  ;-)
Install DJI Flight Simulator from DJI, Free Trial, you don't need to execute it after, it will install the correct USB Drivers
Connect your RC, Whaouuu, DJI Assistant 2 last release can see now your RC  ;-)
2019-1-7
duhs10
bib60 Posted at 1-7 12:53
Hi Everybody
Thanks! Worked perfectly!!
2019-1-7
CriZUndercover
DJI Thor Posted at 1-6 03:32
I still can´t connect my aircraft to my laptop. The driver looks installed and working on my win 10 system but i still have the connecting and disconnecting sound
2019-1-7
DJI Thor
CriZUndercover Posted at 1-7 13:46
I am sorry to hear this situation, as suggested on the PM, I may think the USB C port on the drone is loosened, could you please also check the port and see if it is damaged?
2019-1-9
DJI Thor
Hi Everybody
Great job, bib60. Thanks for sharing the workaround.
2019-1-9
