Help - Mavic Air RC Windows driver required
12345Next >
29064 190 2018-3-24
cyborg
Flight distance : 123960 ft
Singapore
I can't get the RC to connect to DJI Assitant 2 - Windows 10 64bit. I went thru the various threads on this topic and tried some solutions which were discussed earlier (like installing older verison (1.0.7)of Assistant which can install the correct Windows drivers and then upgrade to latest Assistant (v1.2.3)). But even though the device manager list the usb device as a stable connection (still with the yellow exclamation mark), the DJI assistant 2 does not recognize the RC.  I see some posts where the Mods have PMed the RC drivers download link to some users, think I will need that too. I have PMed couple of Mods, but no response yet. Can anyone please provide me the link.. Thanks..!!
2018-3-24
Wachtberger
Flight distance : 261509 ft
This is the one that was made available: https://drive.google.com/file/d/0B4jKLmmRYhQaX3pYOXJRWkpzSFE/view
I hope it will solve your problem!
2018-3-24
cyborg
Singapore
Wachtberger Posted at 2018-3-24 00:31
Awesome, thanks Wachtberger..!
I will try it and report back..
2018-3-24
cyborg
Singapore
@Wachtberger , happy to report it worked. Thanks again..!!
2018-3-24
Wachtberger
cyborg Posted at 2018-3-24 01:45
Good to hear! And does it still recognise the Air too? If not, just reinstall DJI Assistant and then both will work well.
2018-3-24
cyborg
Singapore
Wachtberger Posted at 2018-3-24 13:43
Thanks, MA connects fine with DJI assistant
2018-3-24
Bluehook
Flight distance : 790814 ft
Didn't work for me.  I have Version  V1.2.3 -- I tried everything?
I'm connecting the RC via the micro USB -- the only thing I didn't try was connecting via the standard USB.
@cyborg
2018-3-25
Wachtberger
Bluehook Posted at 2018-3-25 06:53
Sorry to hear that. The strange thing is that for quite a number it works, for others not. I hope that DJI will solve this soon!
2018-3-25
Bluehook
Wachtberger Posted at 2018-3-25 08:01
Thanks for your response.
Can the RC firmware be updated via the phone/connected to the AC?
(That's how I updated the AC firmware twice and it worked really well)
TIA
2018-3-25
Wachtberger
Bluehook Posted at 2018-3-25 09:34
Yes it can as long as you have a WiFi or cell internet connection. Just with DJI Assistant everything is much more comfortable and smooth. Therefore I hope that these issues will be solved soon for all users!
2018-3-25
Bluehook
Wachtberger Posted at 2018-3-25 11:22
Thanks again W!
So, I got into the section in the app where updates are done and the RC and it's version is listed there, but it neither says it needs an update, nor does it have the box to update.
I've been chomping at the bit since 8am to fly this thing -- think I'll be alright?
2018-3-25
Wachtberger
Bluehook Posted at 2018-3-25 11:54
Thanks again W!
There is no update for the RC right now, you should be fine if you have completed the AC and all batteries!
2018-3-25
Bluehook
Wachtberger Posted at 2018-3-25 11:59
Thank you, sir!
2018-3-25
DJI Thor
Flight distance : 13602 ft
Thanks for Wachtberger's help.
2018-3-25
DJI Thor
Thanks again W!
You can check whether your RC has updated according to the firmware info (General Settings--About). For the RC connecting issue, may I know what system is your PC? Have you tried to change another connecting cable? You can try to change the cable. BTW, the RC is able to update via the DJI GO 4 app, no worries.
2018-3-25
cyborg
Singapore
@bluehook... i took me a while to get it connected. I tried all possible solutions mentioned here in various threads, like uninstalling 1.2.3 and downgrading it to 1.0.7, then upgrading etc.  Initially with 1.2.3 the RC used to appear and disappear in the Win device manager continuously (as a USB and COM device). After downgrade to 1.0.7 the device was stable but still without a proper driver (yellow exclamation in the device manager).  Then I installed the Driver which Wachberger provided the link, but even after installing driver RC was not recognized in DJI assistant. So I had to go thru the downgrade, upgrade cycle once again and after the final upgrade to 1.2.3 and PC restart the RC was recognized and I could see the current version details.
But as mentioned here
(1) You can do all the upgrades thru the phone Dji go 4 itself, but I think you can't see the version history, refresh the firmware if required, or downgrade firmware etc thru the phone app.
(2) This firmware is only for MA and batteries, so you don't have to worry about the RC for now.
However, it is good to have everything connected thru DJI Assistant 2 since it displays the firmware version history, logs etc in a proper way. So hope you can get that RC connection going.
2018-3-25
Bluehook
DJI Thor Posted at 2018-3-25 21:28
Thank you for your response.
Windows 10.
Yes, I have tried a different cable to no avail.  I tried it as a matter of due diligence not expecting different result because all along, the computer acknowledges that a device is being plugged into the USB -- but cannot ID it.
Because there is no update, nor warning, via DJI GO 4 app, I'll assume that the update was performed on the RC when I updated the AC.  It shows as version 01.00.0100  and I believe that that is the current version.
The issue of DJI Assistant 2 not seeing the RC, remains.
2018-3-26
Bluehook
cyborg Posted at 2018-3-25 22:56
Thank you sir for sharing the details of your experience, I really appreciate it.  I am focused on your words as being my only remaining solution.
I will try the downgrade, install/uninstall method either today or tomorrow and report back.  Thank you again.
2018-3-26
cyborg
Singapore
Bluehook Posted at 2018-3-26 07:53
also please make sure you delete all files/folders under C:\Program Files (x86)\DJI Product  everytime you uninstall a particular version for downgrading/upgrading the DJI assistant.Hope you can get it working
2018-3-26
Bluehook
cyborg Posted at 2018-3-26 17:10
Thank you again, sir, for your assistance.  I tried everything you suggested and it didn't work.
I've officially given up -- I'll stand by and wait/hope that DJI figures it out.  Until then, I can update the RC via the phone.
If nothing else, it's encouraging to know that there are knowledgeable people, like you, here who are willing to help out a fellow hobbyist.
Much appreciated.
2018-3-29
DJI Thor
Bluehook Posted at 2018-3-26 07:48
Windows 10.
Hi there, could you please tell me what your PC system type is (Window 32 or 64)?
And I got a new driver for you to try, I'll PM you the link. If you decided to use this driver, please install this driver when the RC is connected to the PC, keep the RC powered on during the installation. After finish, you need to restart the RC. See if it helps.
2018-3-29
cyborg
Singapore
Bluehook Posted at 2018-3-29 09:41
That's unfortunate
Looks like DJI Thor has sent you a new driver. Hopefully that one works. Good luck and always happy to help a fellow hobbyist   Cheers..!!
2018-3-29
Bluehook
DJI Thor Posted at 2018-3-29 18:32
Got it, thank you.
I'm running Win 10, 64-bit.  Should I install this to the latest DJI Assist 2 version (1.2.3) or to the downgraded version (1.0.7)?
I'll try it later today and report back, thank you.
2018-3-30
Bluehook
@cyborg said:
That's unfortunate
YES!!  IT WORKED!!
For the benefit of anyone else reading along who find themselves in the same predicament, here's what I experienced:
The DJI Assist 2 version I had installed was 1.0.7  at the time of driver install
DJI Assist 2 program was not opened
RC on and plugged into USB - (RC beeped a few times and booted down during intsall)
After the driver install, DJI Assist 2 version changed to 1.2.2.859
Thank you DJI Thor -- Thank you cyborg.
2018-3-30
DJI Thor
Bluehook Posted at 2018-3-30 08:12
YES!!  IT WORKED!!
Thank you very much for the update and glad it worked. And appreciate your sharing the experience. Hope it also helps others who have the same issue.
2018-4-2
JJBspark
Flight distance : 12225059 ft
DJI Thor Posted at 2018-4-2 02:22
Hi DJI Thor, is it possible to write a update driver document (step by step what to do), and ofcourse make that driver available for all W10 64 bt users.
Thanks in advance
Cheers JJB
2018-4-2
cyborg
Singapore
YES!!  IT WORKED!!
Great news..!!!
2018-4-2
DJI Thor
JJBspark Posted at 2018-4-2 03:07
Thanks in advance
Cheers JJB
Hi there, we need to confirm and would love to have users feedback on the driver. So if anyone is interested in it, please let me know. And remember to provide me with the feedback.
2018-4-4
JJBspark
DJI Thor Posted at 2018-4-4 05:28
Hi Thor, i would love to test this driver, so if you sent me a PM with detailed instructions etc i will test and gve you feedback. Regards JJB
2018-4-4
DJI Thor
JJBspark Posted at 2018-4-4 07:15
I had replied you via PM, please check.
2018-4-6
MIX_DP
Flight distance : 50397 ft
Ukraine
What about driver for WIn 7?
2018-4-20
MIX_DP
Ukraine
Hay?!
How i can connect\install my Mavic Air RC to PC with windows 7???
Trick with old version of DJI Assistant2 didn't help.
2018-4-24
djiuser_YmSWRHeXTqn6
Flight distance : 258432 ft
i am running win 10 64  bit pro can i to have the driver to test
thanks
2018-4-25
BigRoyBoy
Flight distance : 106414 ft
Yes please. Same issue as above and would like to try the update driver.
2018-5-7
BigRoyBoy
Yes please. Same issue as above and would like to try the update driver. W10 64 bt users.
2018-5-7
DJI Thor
BigRoyBoy Posted at 2018-5-7 14:52
Sorry for the late update, Roy. I had PMed you the link to download the driver. Please connect the RC to the PC and keep the RC powering on when installing the driver. Then restart the DJI Assistant 2 and the RC and connect again. See if it helps.
2018-5-14
DJI Thor
djiuser_YmSWRHeXTqn6 Posted at 2018-4-25 18:53
thanks
Sorry for the late reply. I had PMed the link to the driver. Please refer to my reply on 36#, see if it works.
2018-5-14
DJI Thor
MIX_DP Posted at 2018-4-24 23:30
Hay?!
Sorry for the late reply. Did the issue resolve? If no, please try the driver I PMed you. Please refer to my reply on 36# when installing the driver, thank you.
2018-5-14
GDL
Flight distance : 2768694 ft
Singapore
Is there a RC driver available for Windows 7 64 bit?
2018-5-15
SBasso
Malta
DJI Thor Posted at 2018-5-14 23:55
Hello Thor,
Can you also PM the driver...as the very first one shared in this thread did not work for me.
I hear constant beeps, connecting and disconnecting...
The aircraft is easily recognized by the software, however the RC not.
Thanks in advance,
2018-5-15
12345Next >
