Flying the Spark in Fog
1829 23 2018-3-24
Hawkeye55
Flight distance : 13110 ft
I wanted to share my experince attempting to fly my Spark in the fog.  We are in NC mountains in heavy snow.  The snow quit and if was very very foggy.  I didn't give it much thought.  It was a bad experience.  On the first attempt I took it up about 50 ft..  It acted strangly and was not consistently responding to the remote.  I got a bottom sensor failure warning.  I was able to land it although it acted strangely.   I was not smart enough to stop so I restarted everything and tried again.  The second flight was worse.  It went up and started basically going crazy.  I tried to bring it in.  I was clearly not in control.  It landed on the gable porch roof in a light crash fashion and the props overload and it quit.  It was in about 5 inches of snow.  I went out a window to retrieve it and lost my footing and was saved when my foot caught the gutter about 2 ft. below me.  If not for the gutter, I would have fallen about 8 ft.
I learned two lessons.  Don't fly this thing in fog as it is clearly not designed for such.  Don't go out on a snowy roof for the #$$@ thing, get the broom!!
Seriously, the fog made the Spark behave very strangely.  Hope to save someone else here from making this mistake.
Hawk
2018-3-24
flydav
Flight distance : 184226 ft
I believe it's a well known issue, fog and clouds trigger the proximity sensor and the spark thinks it should land on those.
2018-3-24
flydav
I believe it's a well known issue, fog and clouds trigger the proximity sensor and the spark thinks it should land on those things.
I'm fairly new on drones and this forum as well and I'm trying to read as much as possible here to avoid doing stuff I shouldnt do with my spark. I suggest you do the same it could have saved you the time and struggle of this bad experience you just had.
P.S Why do I have only 2 minutes to edit a post?!?!?
2018-3-24
marlowe
Flight distance : 300932 ft
Try reading the manual - p. 46: "Do not use the aircraft in...fog."
2018-3-24
Hawkeye55
marlowe Posted at 2018-3-24 16:31
Truthfully, the paperwork that came with the drone was tiny and not well written unless I missed something.  I have learned by reading here and some great youtube videos.  No argument with your advice though.  It's actually the first mistake I have made with it.  I have been very cautious.
Thank you
2018-3-24
EMTDad
Flight distance : 247933 ft
I had the same issue up here in Cleveland, except I was flying it in snow.  (Obviously I know that this is not recommended, but felt it would be a good video).  The bottom sensor was acting up... But the forward facing collision sensor went NUTS!.  I had to disable the obstacle avoidance system in order to get any control over it.
2018-3-24
The Bash's
Hey if there wasn't any trial, there wouldn't be any error, you know for us to learn off of... I downloaded the manual then I found this thread https://forum.dji.com/thread-118 ... b7938&pm=custom ... Doesn't mean curiosity won't get me to fly in tricky weather.
2018-3-24
Rustic17
Flight distance : 1217336 ft
Hawkeye55 Posted at 2018-3-24 17:51
Thank you
You can easily download the manual from the DJI Spark downloads section.
2018-3-24
marlowe
Thank you
Yes - you missed a lot. This is not entirely your fault. If DJI is not going to include the user's manual with the product they should at least provide a "start-up" sheet with a link to where you can download it and a statement to "read this first!"
That said -- this is a complex product and the lengthy manual is not an easy read (actually it is too short). It (the English version) could be much better written. I doubt that most people who read thru how RTH works fully understand it.
A lot of the important things you will find on you tube videos should be in the manual.
2018-3-24
Gunship9
I have heard rumors that flying operations and flying safely is complicated.  Lots for a pilot to learn and read.  No cliff notes to learn it all so one has to read a lot.  On the plus side with drones, remotely piloting aircraft allows pilots to learn by trial and error if they are so inclined.  I landed quickly when my lower sensors started complaining about the light fog in the area.  Live and learn.
2018-3-24
Gunship9
flydav Posted at 2018-3-24 16:03
Only two minutes to edit a post because you are lvl.1
Higher levels can edit more freely.  I think I am supreme commander level now days.
2018-3-24
Flighty
Flight distance : 1977175 ft
Croatia
I flew my Spark in Fog with disastrous results, then read the manual referring to flying in weather conditions,, (Fog),,, now I am very cautious and read the manual quite a lot..
2018-3-25
KurtVD
Flight distance : 365299 ft
Switzerland
Gunship9 Posted at 2018-3-24 20:08
What do you mean “you heard rumors “? We own one ourselves, why should we rely on rumors?
The DJI drones are objectively some of the easiest drones available today (with that much functionality), someone who’s never flown an RC aircraft before, can buy a Spark and will be able to film aerial videos within an hour after unboxing. Plus it’s quite rugged and can easily survive a crash if you’re not too unlucky.
But this also incites people to take unnecessary risks, just because it’s so easy to control and flies so well. Most crashes happen in these situations, I think.
2018-3-25
Gunship9
KurtVD Posted at 2018-3-25 10:09
"The DJI drones are objectively some of the easiest drones available today (with that much functionality), someone who’s never flown an RC aircraft before, can buy a Spark and will be able to film aerial videos within an hour after unboxing."
Sometimes they can and sometimes "My drone flew away" is posted to the forums.  Continuous successful missions require knowledge about flying and flight safety.  People arguing about reading manuals.
My theory is the autopilot flies it so well.  They don't.  So as soon as the autopilot is offline or has issues, the crying starts.
2018-3-25
Jerpie
Flight distance : 191211 ft
You made me laugh.
2018-3-25
marlowe
That was my intent. Since both the pilot and the Spark seemed to have survived the ordeal, I thought a bit of humor was in order.
2018-3-25
KlooGee
Flight distance : 11897329 ft
Thanks for sharing your story.  Hopefully someone else sees this and learns from it so they don't have to fall off of their roof retrieving it.  We've all had to learn something the hard way at many points.  As long as nobody gets hurt or arrested in the process, we can have a good laugh at it later.  Cheers!
p.s. Definitely download the manual from DJI's website:   https://www.dji.com/spark/info#downloads
2018-3-25
DJI Elektra
Thanks for sharing your story and reminding other users. Please read our user manual carefully and it includes the things that have a bad influence on VPS.
2018-3-25
MJLSTUDIOS
Flight distance : 1540131 ft
You didn't turn on the fog lights!?
2018-3-26
flydav
Gunship9 Posted at 2018-3-24 20:10
Oh thanks for letting me know... I can't believe it! Ive never had such limitation on any forum I've ever been in the last 20 yrs!!! Honestly I can't understand why one would limit the time a user has to edit his post and then doing it according to his level?! There is always the first time I guess!
2018-3-26
m1n1s
Flight distance : 319915 ft
i had a spot of bother just before xmas when flying on a cloudy day near the cliff edge , the spark got stuck in some light cloud which wasn't visable from where i was stood and tried to land and did some crazy stuff.
when i watched the video back from the sd card later i could see the spark fly into the cloud.
sports mode saved the day and 70% battery left
Sparky no.3 got lucky.........
2018-3-26
Viking-Pilot
Flight distance : 2379249 ft
Lucky it all ended better than it could have...
2018-3-27
A CW
Flight distance : 13674072 ft
Always best to keep you drone away from any form of moisture - including fog!
2018-3-27
Kerky
Flight distance : 28655 ft
Thank you
Tiny, I agree, I downloaded them off the internet and did some reading even before I held the Spark in my hands. But it is quite well written in my opinion, way beyond the usual chinese manual translations.
2018-3-27
