DJI Phantom 3 Advance No Image Transmission Signal
hung1028
Mexico
I had a crash the last time I flew my drone and this issue happened after that. Whenever I try to take a picture or switch from picture mode to video mode, it appears that there is No Image Transmission Signal.......I tried to update the firmware but there is no luck...... Can somebody help me? I need it for my work......
2018-3-26
C&A I.A
Flight distance : 312579 ft
Brazil
test turn off your wi-fi connection (if on)
2018-3-26
C&A I.A
Brazil
I had a similar problem. You can also test with another memory card. it may be that what you are using is with some damaged track so it takes so long to capture the photo or change the capture mode
2018-3-26
ALABAMA
Flight distance : 10442687 ft
Send back to repair.
2018-3-26
djiuser_gl6QNuvh5GV1
Flight distance : 18832 ft
Check all cables to gimbal board make sure you hear  a click off both
2018-3-26
DJI Susan
Sorry to read the crash. It is recommended to start a case and send the unit in for diagnosis. Please kindly start a case from here and arrange at your earliest convenience: https://www.dji.com/support
2018-3-26
djiuser_G5pg0RDXYx3Y
Argentina
Hi, did you find out what ther problem was? I have the same problem now
2019-8-7
Anthonyg
Flight distance : 183054 ft
I've just had the same problem. Used a different memory card and now it's working.
2019-8-7
