Bug in EL Mode
1034 6 2018-3-26
Coyut
Flight distance : 2559222 ft
Switzerland
When choosing EL Mode, the iso display on the camera operator Cendendence does not work. It stays at 100 and can't be changed from the RC.
2018-3-26
I guess you mean EI mode, in this mode, ISO settings are replaced with EI. Users can adjust the EI value with DJI GO 4 or remote controller.
I have tested with Cendence, EI value can be adjusted, any chance to share us a video about your issue?
2018-3-27
YOYOMAN
Flight distance : 676260 ft
Réunion
Check your Cendence Firmware Version. If you have .30 firmware (who is the latest available on dji.com) you're not lucky (that's my case) and you would have to wait the next release one day (or not) for
If you have the .45 firmware (still not available on dji.com), you're lucky and  changing ISO should work (I dont use EI so I don't know about it)
good luck
2018-3-27
Coyut
Switzerland
DJI Mindy Posted at 2018-3-27 00:27
Value can be adjusted but the value in the Cendence display remains at 100
2018-3-27
Coyut
Switzerland
YOYOMAN Posted at 2018-3-27 00:52
good luck
I'm already on .45
2018-3-27
I have tested again, it seems so, appreciate your feedback, I will report the issue to our engineers to look into, will come back to you once I hear from them, thanks for your patience.
2018-3-27
uasflightops
Flight distance : 1273983 ft
Any updates on this?
2018-5-3
