fansc35f59ab
Flight distance : 158770 ft
RichJ53 Posted at 2018-3-28 08:10
This product is very useful on the battery connections and the camera mounting contacts. I use this on all my drone contacts.... works great
Rich
All,
I think I learned a little something here. It appears to be a combination of issues. The connector was loose. But also, We were lowering and raising gear in a low light situation on a hotel convention hall carpet. (colors that cannot be described by the Human mouth) The gear would not function over this carpet , but would function on a white table. Also, if something is under the drone ATT sensors , it will not lower all the way. Seemed to be consistent in this. Took it outside, worked fine. Either the low light or the carpet does not allow the sensors to determine altitude which then affect landing gear articulation.
Thanks for all your help! |
