Matthew Chirico
Flight distance : 769160 ft
what if you import 4k video at 23.976 fps, but your sequence is at 2.7k dimensions and you want to export at 2.7k...questions:
1. does editing 4k footage in a 2.7k sequence and then exporting the 4k footage at 2.7k have any negatives?
1a. would you export at the same settings you mentioned above?
2. since I took 4k footage should I just export at 4k or is 2.7k better? (I've heard that it is...if so, why?)
2a. if I export at 4k what should my export settings be?
3. does the sequence dimensions you're editing in affect the outcome of the video? Or is what your exporting dimensions are (4k or 2.7k), all that matter?
3a. would exporting at 4k from a 2.7k sequence dimension have a difference from exporting a 4k video from a 4k sequence dimension?
Summary:
I just want the cleanest, sharpest looking exported video (In the end will be uploaded to YouTube, etc.)
If I take all my video at 4k, 23.976 FPS...what are the Adobe premiere steps to attaining the best looking footage?
