Inspire 2 with X5S, camera gimbal not initiating
1492 7 2018-3-28
vizform
South Africa
I am very frustrated at the moment. My Inspire 2 with X5S camera won’t initiate the camera gimbal movement. When I startup the drone, the camera rotates 90 degrees and then rotates to either the left or right corner and then gets stuck there. It is also not responding to any of my rotation inputs from the dji go 4 app. This is extremely inconvenient as I just spent a lot of money to travel to the other side of the country to do a shoot for a client and my camera does not want to work. It was working fine yesterday. I booked the drone on a cargo flight yesterday and this morning when I tried flying it, it did not work. There are no signs of damage on any of the equipment.
2018-3-28
vizform
South Africa
I didn’t do any firmware updates, only now when it stopped working, did I upgrade to version 1.300, but it is still not working
2018-3-28
Des_B
Flight distance : 129600 ft
When you power up the inspire 2 do you get the melody?
Is the video link working?
If you remove the camera, and then power up does it work then?
Need to know a little more
2018-3-28
vizform
South Africa
Des_B Posted at 2018-3-28 02:51
Thanks for the reply.
I am getting the melody
The video link is also work and I can change the camera settings.
I have uploaded a video to show you what I am talking about.
[/b
2018-3-28
Des_B
Sorry Viz,
I assumed that you meant the I2 wasn`t working also.
I suspect a gimbal electrical fault, ideally a swap out with a known good gimbal would give the definitive answer.
Hopefully  there is a dealer or another I2 owner in S.A. who could help, if not, looks like it is back to DJI for investigation and repair.
2018-3-28
vizform
South Africa
Des_B Posted at 2018-3-28 04:45
Sorry Viz,
Thanks Dez,
We have a dealership in Cape Town, I will send it to them once I am back there. Luckily I could ship my old inspire 1 to my location in time.
2018-3-28
RobAlbania
Albania
Seems likely to me that the internal cable (inside the I2) that powers the gimbal motors has come loose.
2018-3-28
Sorry to know you are experiencing difficulties, please remove the gimbal, enter Travel Mode and then exit, attach gimbal to try again, besides, did you try to flash the firmware via DJI Assistant 2?
2018-3-29
