HEAT buildup
1106 5 2018-3-28
pyott
Flight distance : 4511 ft
Never owning a gimble prior to this one, I have a question about heat, is it typical for the motor at the control area to get Moderately hot?  It's not hot enough to burn you but I em concerned about it being hot enough to melt wires, is this normal?
2018-3-28
Indio
Flight distance : 303373 ft
Austria
the motors will be hot if the gimbal is not balanced good enough
2018-3-28
Montfrooij
Flight distance : 2560453 ft
What product are you using?
2018-3-28
Hi pyott, how long will the motor get hot after you power on? Please make sure the gimbal has been balanced well before you switch on, here is a tutorial video about how to operate Osmo Mobile 2 for your reference:
2018-3-29
pyott
As far as I could tell it was well balanced, I did follow the balance directions when I first got it.  Only the lower motor was getting hot.  The one above the controls.  Others didn't seem to be.  It had was on and off during a 1 hr performance.  Total run time might have been 30 minutes and I hadn't noticed the heat until near the end of the performance.
2018-3-29
pyott Posted at 2018-3-29 08:29
Please do more test, if the gimbal motor gets hot very quickly when you switch on and only one the motor is hot, I recommend to send in for evaluation.
2018-3-30
