Missing Colors in Photos and Videos - Hardware or Software failure?
675 10 2018-3-29
michaelulm
Flight distance : 38445 ft
Hi,
I have a Mavic Air since two weeks and I observe a very strange behaviour. In some areas colors are missing in my final footage (4K, mp4).
I've uploaded one video to youtube where you can see that colors are missing:
Video 2
another video where you can see how colors are coming and going when rotating the aircraft
Panorama
In the following panorama you can see that color is missing around the center of the image:
Screenshot of Video (final footage):
Colors are missing in some places, but are correct in other places
Same video, in my DJI_RECORD folder on Android:
colors are correct everywhere
DJI support said I should replace the aircraft, but can this really by a hardware failure?
Thanks for your help.
2018-3-29
XAFAfterShock
Flight distance : 40771 ft
what camera settings were you using, whitebalance, iso, shutterspeed, were you using d-cinelike or a custom style settings?
2018-3-29
Woe
Flight distance : 4129268 ft
Check your camera settings.
2018-3-29
michaelulm
Hi,
my camera settings are:
4K/24fps; MP4; AWB; Style: none; Color: none.
I resetted the settings a few times and the error occured even at flight number one, without any adjustments made to the settings.
As you can see the colors are correct when shooting RAW-Photos or in the video folder (DJI_RECORD) on my android smartphone.
2018-3-29
cspain
Flight distance : 662644 ft
Turn off AWB and set it to one of the presets or set it manually. In fact, I would make sure everything is on manual:
AWB - put on preset like "Sunny"
ISO - 100
Turn on histogram
Set the shutter speed until the histogram peaks near the center (do this while in the air).
2018-3-29
Montfrooij
Flight distance : 2560453 ft
Looks like white balance issue to me.
2018-3-29
michaelulm
Sorry, I already tried different AWB settings and it didn't get any better.
How could this even be a white balance issue? If the color temperature is too high the entire image would be warmer (more orange), if the color temperature is too low the entire image would be colder (more blue).
2018-3-29
michaelulm
Hi, i have another example to show the effect. Although the wall on the left is slightly brown: Even if I increase saturation in After Effects 90% there's almost no color information.
2018-3-30
Kevjones1959
Flight distance : 61932 ft
South Africa
You say the RAW file has the correct color information ? If so then it's more than likely a software issue not hardware. Unless the MOV mode is using a completely different chip.
2018-3-30
michaelulm
Yes, photos shot in RAW-format have perfectly valid colors. I would also think that it's a software bug, but it seems I'm the only one experiencing this issue, which points to a strange hardware bug. I didn't find anything related online, even for different models.
2018-3-30
michaelulm
I received my replacement unit today after shipping it to DJI Europe last tuesday – that's was much faster than I expected. I took the same picture again and colors are now much more accurate, even in low light conditions.
2018-4-12
