Do I or Don't I?
Oscar Myer
Malaysia
Greetings all!!!
After wanting one for so long I got myself a brand new Phantom 4 the other day.  It is technically still in the box.  I've turned it on in the house a couple of times but have not attempted to fly it outdorrs as of yet.  Because I've never flown a drone before there's a bit of anxiety involved as I consider the price I paid for it.  It would really be a drag if I crashed it the first time out. Seems that threre's so much to learn.   That and the fact that there is still quite a bit of snow on the ground here in Montreal, Canada.
I've been reading so many horror stories from people who are having so many problems after upgrading their firmware.  My question is, should I update my firmware before taking my P4 out for it's first flight or should I leave the factory settings as they are?
Any help I can get from all you seasoned pros out there would be greatly appreciated.
Bobby
2018-3-29
Oscar Myer
Malaysia
Opps... I clicked on "Phamton 4 advanced"... this is certainly NOT the case!!!
2018-3-29
Aardvark
Flight distance : 384432 ft
While you're waiting for the snow to clear read through the Manual  (A good bookmark, loads of info' on that page) a couple of times. Pay particular attention to the section on Return To Home (RTH). You shouldn't really rely on it, but if it initiates for some reason then you need to know exactly what to expect and what control you have.
So start off in a wide open area, no trees or obstructions, leave it in beginner mode for the first few flights until you build up confidence that it usually does what it says on the tin.
I would leave any upgrades for a week or two, to prove that there's nothing wrong initially when first unboxed. For most the latest builds for the P4 are stable and have overcome some problems that have been plaguing the P4 since last July.
Always fly with fully charged batteries, and during cold weather do not ignore any battery temperature warnings, let aircraft hover beside you for a minute or two to let batteries warm up a bit so that they can deliver the current for the load required.
Oh, and, have fun
2018-3-29
A CW
Flight distance : 13926112 ft
Don't hold me responsible if anything happens but I always update the FW to the latest version using DJI Assistant 2 on my MacBook. Same as the latest IOS and GO 4 app versions too. Congrats on your new purchase - I suggest reading the manual thoroughly and watching the tutorials as part of your prep then find a quiet, wide open area and start flying - small steps to begin with (in beginner mode) then allow your confidence to build. You'll be recording 4K video at 400' AGL then flying around at 45MPH a mile away soon enough - just take your time learning it. You don't get in a car for the first time and drive down a motorway at 80MPH on your first lesson...
2018-3-29
Montfrooij
Flight distance : 2560453 ft
I did update everything before taking off.
But that is just me.....
Worked perfectly though.
2018-3-29
Oscar Myer
Malaysia
Thanks so much for the replies!!!  As for what mode I'll start off in... beginner mode has already been selected and will probably stay that way for quite a while.
I've already figured out on my own that reading the manual is a must.  I started reading it the other day and got as far as page 30.  I have a couple of hours free today and plan on starting over at page one - just to refresh my memory.  The old brain is just a tad slower than it used to be.
DJI Assistant 2 has already been installed on my Windows 10 PC.  But when I start it up without the RC and P4 turned on it tells me to plug in my "Aspire".  Is something wrong with the installation or does my equipment need to be turned on for Assistant 2 to see my P4 instead of Aspire?
2018-3-29
Aardvark
Oscar Myer Posted at 2018-3-29 06:20
"Is something wrong with the installation or does my equipment need to be turned on for Assistant 2 to see my P4 instead of Aspire?"
That's correct, it needs to see your aircraft connected and powered up.
It's a notification for those with an Inspire as the connection needs to be activated on the Inspire, that's why it is shown as default.
2018-3-29
ALABAMA
Flight distance : 10442687 ft
It should have been tested before being shipped, so it should fly perfectly. I would definitely not update until you have learned your expensive purchase inside and out.  Start out slow and take baby steps.
2018-3-29
sidtx
Flight distance : 266729 ft
I'd also recommend that you watch the tutorial vidoes that are our on Youtube.
There's some really good ones that take you through initial and safe flights,  to more sophisticated flights (including ATTI mode flight) as you gain experience.
It may seem silly when they recommend flying a small circle,  or flying a rectangle pattern -- but there's a good reason for the small steps -- experience and confidence.
I watched a series of these training videos before I ever flew my P3.   It really helped when I actually got into the field and I was more confident as to what the drone would do (and wouldn't do).
Sid
2018-3-29
Oscar Myer
Malaysia
Aardvark Posted at 2018-3-29 06:55
Thanks so much for clearing this up for me!!!
2018-3-29
Oscar Myer
Malaysia
ALABAMA Posted at 2018-3-29 07:16
Yes... expensive purchase indeed.  Therefore I want to know as much about it before I even take it out of the box.  I was thinking about getting one of those $200 toys at first.  But when I saw the difference between the P4 and all those cheaper ones I decided that I wasn't going to waste $200 on something that I'd only want to upgrade in a month or less.
2018-3-29
Oscar Myer
Malaysia
sidtx Posted at 2018-3-29 07:28
Yes... I have been watching hours of YouTube since last week.  I've even watched some of them 2 and 3 times.  I also have the manual on my desktop and am making good use of it.
2018-3-29
Oracle Miata
Flight distance : 3759829 ft
What exactly is your Avatar?
2018-3-29
DJI Susan
Hello Oscar, welcome to join the Phantom club!
As the above mentioned, it's always a good habit to read the manual thoroughly. Feel free to ask your questions here if you have any doubts.
Also, practice makes perfect. With some hands-on experience, you will know better the drone's performance.
2018-3-29
RedHotPoker
Flight distance : 165105 ft
I only have Two words. Flight SIM. Haha
RedHotPoker
2018-3-29
Oscar Myer
Malaysia
Oracle Miata Posted at 2018-3-29 11:59
I guess it may have looked a bit better before I had to crop it to fit my avatar.  Perhaps I'll have to use something else.
2018-3-30
FatherXmas
Flight distance : 4058619 ft
Be aware, some folks with Windows 10, myself included, have had an issue with Assistant 2 device drivers not being installed. If that is the case, your Phantom will never be detected by Assistant 2. The fix is easy, uninstall Assistant 2, then follow the steps to allow unsigned drivers, then reinstall Assistant 2.
https://www.maketecheasier.com/i ... -drivers-windows10/
2018-3-30
Oracle Miata
Oscar Myer Posted at 2018-3-30 05:39
[view_image]
Awesome Cat!
2018-3-30
Bashy
Flight distance : 2354357 ft
Before you update the fw, check to see what versions you have post a screen shot of the about page in the app settings on this thread, we do know of issues on certain FW and if you have one of those then it would be prudent to update...
2018-3-30
Oscar Myer
Malaysia
Bashy Posted at 2018-3-30 20:25
Here's a reply from a complete newb... sorry if it sounds stupid but... I don't know how to post a screen shot.  Mebbe you can help me out with that?  (this is another reason why I haven't flown my drone yet
2018-3-31
Bashy
Might be easier for  you just to type it out for now
2018-3-31
Oscar Myer
Malaysia
Bashy Posted at 2018-3-31 20:59
Yeah... I suppose you're right.  I have enough to learn about flying.  If I have to learn about posting screen shots as well, that might be overload on this old brain.
2018-4-1
m1shootr
Flight distance : 118894 ft
My first Phantom (P3A) sat in the box for 3 weeks before I had the courage to unveil it to the wife. During that period i practiced with a Syma X5 outside and a small inside drone. I also read the P3A manual a couple of times until I was fairly comfortable with the idea of flying an $800 machine.
2018-4-1
Oscar Myer
Malaysia
m1shootr Posted at 2018-4-1 09:22
I know what you mean about having the nerve to show it to the wife.  When I first bought it I thought about sneaking in through my workshop.  But then I figured that she's going to know about it for sure somewhere down the line.  So I manned up and brought it straight in to show her.  I went through the old, what are you doing wasting money on something like that? ... and so on.  The next day, once she cooled down she came around and was even talking about coming with me when I fly it.
My plan was to take it up today for the first time,  but the wind is blowing too hard and it's rather cold.  This week for sure!!!
2018-4-1
sky wombat
Flight distance : 1454078 ft
Oscar Myer Posted at 2018-4-1 12:46
Oscar, strike while the drone is hot and buy her a Mavic
Accept that somewhere along the way you're going to run into a problem (yep bad pun intended) but don't let worrying about crashing ruin getting out there and in the air. Besides, snow is soft right?
2018-4-1
Oscar Myer
Malaysia
sky wombat Posted at 2018-4-1 13:46
I'll only buy one for her if she starts using my P4 and never let's me fly it.
Actually, we've had a couple of warm days and the snow has really gone down a lot.  There's a nice big school yard across from my house and the kids are off all this week on Easter break, soooo....
2018-4-1
