how to view 360 sphere panorama on windows PC
61730 12 2018-3-29
parafux
Flight distance : 340010 ft
I just tried the 360 panorama mode. and got a stiched jpeg and 25 dng files on my sd card.
how can i view this panorama pictures in interactive mode on my pc. i dont want to use my mobile phone for this.
2018-3-29
Wachtberger
Flight distance : 261509 ft
On Skypixel for example or here:  https://kuula.co/share/7lXV8?thumbs=1&chromeless=1&logo=0
And there are more that I can't remember now.
2018-3-29
parafux
Wachtberger Posted at 2018-3-29 06:55
thank you that is great, and pretty enough for me. i just needed to create an free account and had to upload my single stiched jpeg file that comes from the sd-card on the drone.
2018-3-29
Bielsko360pl
Flight distance : 104669 ft
Poland
For PC - use FSPViewer - freeware.
2018-3-29
SPLflyer
Flight distance : 144829 ft
In my opinion the program &aposanoramaStudio 3 Pro', in combination with the really good raw pano photos of the Air, has the best (and simplest!) conditions for a high-quality pano. My workflow (with a not too differentiated, mainly blue sky) goes like this:
1. PanoramaStudio 3 Pro imports Air-DNGs, but distorts them in color, so I first open the 25 DNG photos in Photoshop (Camera Raw with initial pre-sharpening) and then save them as 16Bit TIFFs for PanoramaStudio 3 Pro.
2. Select multi-row Pano in PanoramaStudio 3 Pro and import the 25 TIFFs. After calculating the panorama, drag the red cropping frame up to the top edge of the image to capture the entire image, including the empty sky.
3. Save this image as TIFF and open it again in Photoshop. Use the 'rectangle selection tool' (I don't know the exact english terms, because my PS is german ) to mark the empty sky area (including the arched sky edges).
4. Select the 'Fill area...' function under 'Edit' and fill the empty area 'Content-based'. The result can be further refined with the 'Stamp' and 'Repair tool'.
5. Finally I reduce the image size under PS to approx. 40% (~7480px x 3740px, absolutely sufficient!) and refine the Pano before saving it with different filters (sharpness, colors, tonal value, white balance).
6. Import the finished TIFF-Pano into PanoramaStudio 3 Pro as a 'panorama image' and save it as an 'interactive pano', screensaver or EXE file in the final step. Ready!
If you leave the JPG quality in P3P for the interactive Pano at the default 'normal', the total amount of data to be uploaded to your own web space is approx. 7 MB. Previously, one can smooth the zenith tiles in Photoshop a little to soften the abutting edges of the webpano. And... who looks so closely at the zenith? The result can then look something like this:
http://www.ikarus-webspace.de/content/Pano/Bobzin_Airport.html
(I was allowed to start here, because the plane belongs to me and the airfield belongs to our club! )
Of course you can also view the pano locally on your Windows PC - either in your browser, or as a self-running EXE file.
2018-3-29
Hummingbird.UAV
Flight distance : 3313248 ft
If you are flying with Go4 before turning off your drone go the play button (lower right) and it will show thumbnails of the images captured.  A spherical pano will have a white circle in the corner.  Press the thumbnail and it will bring up the panorama.  It can be downloaded to your phone and shared to Skypixel.  You can then go to Skypixel on a PC and view in interactive mode.
2018-3-29
arckphoto
Flight distance : 119229 ft
Hummingbird.UAV Posted at 2018-3-29 11:04
When I capture 360 sphere panorama, what I've found is that on Go4 app, the spherical pano image is created automatically in some instances but not the other times. Do you know why there is such inconsistency?  Is it the case that it only generates the spherical image after pressing the play button, before turning off the the drone? Thanks........
2018-7-19
Hummingbird.UAV
arckphoto Posted at 2018-7-19 07:22
I have found that while the pano is being created if any of the controls are touched the pano stitch fails.  When the play button is pressed it only downloads the panos that are already stitched.
2018-7-19
arckphoto
Hummingbird.UAV Posted at 2018-7-19 08:21
Got it thanks...........
2018-7-20
Speleo-flyer
You might like to try PanGazer [http://speleotrove.com/pangazer/] .. I wrote it specifically for viewing my Mavic panoramas!
2018-9-23
Csaboca
Flight distance : 1417 ft
Hungary
Speleo-flyer Posted at 2018-9-23 07:39
PERFECT !!!
2019-1-4
GertCap
Flight distance : 2658914 ft
Fantastic piece of software, thank you!
2019-11-11
djiuser_c2Oa3fqhOreR
Why is Bit Defender identifying this application as a threat?
2021-1-17
