DJI Missleading information
1535 20 2018-3-29
LOMELI
Flight distance : 887031 ft
Mexico
I got this email from DJI today. This charging hub does not charge 4 batteries at a time, it does not even charge 2 batteries at a time. It charges one by one, while there are all connected.
This email should be pulled out and inform all the recipients that there was a mistake. .
2018-3-29
cspain
Flight distance : 662644 ft
Yeah, I learned that after I got it too. The only silver lining is that it does charge the battery with the most juice left first. So, if you have 4 batteries where three are 50% and one is 60%, it  will charge the 60% one first to get you flying again faster.
2018-3-29
Wachtberger
Flight distance : 261509 ft
You only became aware of how it works now? ;-) It does not say "simultaneously", but I admit that the message can be misunderstood. What it means is that you can put four batteries "at once" and leave the charging process going until all are fully charged.
2018-3-29
Hummingbird.UAV
Flight distance : 27489951 ft
Not really, put all the batteries on at one time, come back later and they are ALL charged or do it the old way and go back and forth four times and if you forget there's less batteries to fly with the next day.
2018-3-29
LOMELI
Mexico
Wachtberger Posted at 2018-3-29 12:18
No, I’ve had it since I purchased my combo, and the manual states clearly one by one. Stating charge up to four batteries at once it means at once not one by one.
Misleading, exactly my point.
2018-3-29
Flycaster
Sometimes things get a bit "lost" in the translation. As anything from Mainland China, you have to read, read between the lines, and read again. And "read" what isn't there!!!
No biggie, I just plug them in, and in a few hours all ready to go.
There are a couple of power banks that do "simultaneously" charge up to 4 batteries at once, a bit pricey, but that may be what your looking for/need....
2018-3-29
Monkey007
Flight distance : 73775046 ft
LOMELI Posted at 2018-3-29 12:21
Totally agree the description can be misleading for us ordinary people. But then again, you can buy a third party charger that charges 4 Air batteries simultaneously for 30 bucks. Never really understood the logic behind this sequential charging concept from DJI, apart from the possible cost savings in manufacturing a lower amperage power brick???
2018-3-29
HedgeTrimmer
The wording is misleading.  "at once" would imply all four or all three or both batteries are charging at same time.
2018-3-29
Monkey007
HedgeTrimmer Posted at 2018-3-29 12:44
Yes, and that particular sentence starts with the word 'charge', not 'accommodate', or 'accept'...
2018-3-29
MWitarsa
Flight distance : 2058179 ft
Brazil
When I first read it, I also understood it the wrong way
2018-3-29
hallmark007
Flight distance : 9827923 ft
All your guests arrive at Once but you can only let them in one by one.. lol, a little misleading but if I got caught with it, I’m happy for others to feel the same pain as me...
2018-3-29
LOMELI
Mexico
I don’t need one, nor did I get this. It came with my original purchase. I totally understand how it works.
The whole point of this thread is to make DJI aware that this information is misleading, and judging by the looks of this, other people think the same way I do.
2018-3-29
DJI Diana
Flight distance : 2408 ft
Hi there, so sorry for the misunderstood. The Mavic Air Battery Charging Hub is designed for use with the Mavic Air Intelligent Flight Battery. It can charge up to four Intelligent Flight Batteries in sequence according to their power levels, and from high to low. You can put four batteries at once and leave the charging process going until all are fully charged. Thank you for your support!
2018-3-29
Brad Bilger
Flight distance : 14843274 ft
Not everybody thought that way. I knew how it worked before I got it. But then, I read the manual before I bought my MP.
2018-3-29
HedgeTrimmer
DJI Diana Posted at 2018-3-29 19:04
[view_image]
As LOMELI posted, the Email that he got is misleading.
Email needs to be followed up with one that makes it clear Mavic Air charging hub, only charges one battery at a time, whether there is two, three, or four batteries inserted in it.
2018-3-29
Gunship9
I know the price of power supplies that can charge four flight batteries at high rates all at once.  So it is obvious that four are charged slowly or one at a time.  I have an ex-Dell server power supply that will provide the current I need to charge two 4100mah batteries at 4 C but it would have been $200 if I had to pay for it.  Plus, my charger that charges the 4100mah battery, that runs on the power supply, was $200
Maybe it is only one battery at that rate as 32amps at 12v seems excessive.
That hub is a good deal if only for its ease of use when more than one battery needs charging.
2018-3-29
davidmartingraf
Flight distance : 106566408 ft
Pretty strange how DJI could botch their marketing here on the Mavic Air charging port, but I'm going to give them the benefit of the doubt that they know more than us not to make such an error. In which case, the logical explanation one would draw is expect an upcoming firmware to all Mavic Air owners who purchased the Fly More Combo, as they're going to be getting an update to the battery charger that will allow all batteries to be charged simultaneously (just like the DJI Spark).
2018-3-29
Datadogie
Flight distance : 27028 ft
Think about it all at once for the same speed would need the powerpack to be much much bigger. As it is works fine for me.
2018-3-29
Bigplumbs
Flight distance : 620164 ft
Datadogie Posted at 2018-3-29 22:05
No one is saying that it does not work. The OP was simply stating  that the information put out by DJI was misleading which it was
Dennis
2018-3-29
Montfrooij
Flight distance : 2560453 ft
Taken from the store:
The Mavic Air Battery Charging Hub is designed for use with the Mavic Air Intelligent Flight Battery. When used with the Mavic Air Power Adapter, it can charge up to four Intelligent Flight Batteries in sequence according to their power levels, and from high to low.
2018-3-29
A CW
Flight distance : 13926112 ft
[view_image]
That's clear enough I think!
2018-3-30
