djiuser_d5E84XuWBLpr
Hello, I've gone through several threads related to firmware issues between aircraft and remote but am at a loss.
I have a new, never flown P3P.
From the get-go, I have not been able to connect the DJI GO APP to the remote/aircraft.
I've used the original cable, other cables, and several different devices with no luck.
I was able to update the P3P firmware via the Micro SD card method. (1.11.002)
I am UNABLE to update the firmware on the remote, I've tried the SD method, USB stick method, and directly connecting the remote to the aircraft. No luck so far.
Now, after re-linking the controller, the controller LED indicator light flashes red and green very fast and sporadically. No distinct pattern, it just looks confused.
I can tilt the gimbal with the remote.
I've read in another thread that you may need to upgrade the remote controller's firmware incrementaly, but without ever being able to connect to the app, I have no idea what firmware is on the remote.
I'm in need of some assistance here. Has anyone had this problem and fixed it? My mobile device (s7 edge) will charge from the usb port on the controller, I don't know how else to test the USB board.
