kwis
DJI Mindy Posted at 2018-3-29 23:48
Regarding your concern, the heights are different, please note that the camera is fetching the "fusion height" from the flight control module to write the EXIF information of the photo, please note that the fusion height is calculated by using the barometer and the GPS measurement heights.
However, the barometer is very easy to be affected by the interference from the outside environment, for example, if crosswind blows across the air, the barometric pressure near the barometer will change drastically, causing the barometer to change its height measurement (but actually the aircraft height is not changed, posture may change), besides, temperature will also affect. In general, there are many factors that can affect the barometer.
For GPS, the most important thing is to search for the number of stars. The more stars, the more accurate the judgment of height, and vice versa. GPS also easily receives interference from the environment.
Thanks, but in my humble opinion, that makes NO sense that the altitude would go DOWN when you go UP in the air. It is a BUG in the firmware.. for example, on the ground, I take a picture and recorded altitude is 1065 Meters Above Sea Level.. but when i go UP in the air by 60 meters and take another picture, the EXIF records 1004 Meters Above Sea Level.. the Altitiude has DECREASED, but I went UP in the air by 60 meters???
and you should NOT be using the barometer for altitude as a primary source.. you should only use it when GPS is unavailable for short periods of time or until a good GPS lock is achieved... a good GPS signal is infinitely more accurate..
Why is the ASL going DOWN when the aircraft is going UP ??
A |
