Vaughanabe13
I am having trouble copying files from a microSD card to a USB hard disk on the Crystalsky 5.5. I am using this 1TB hard disk from Seagate, and it is plugged into the USB-A port on the CS550, with the MicroSD card also in the SD1 slot. In the File Explorer, both are showing up just fine, and I'm able to play videos directly off both. I can also copy a large video file FROM the USB hard disk TO the SD card or to the internal memory, so there are no issues reading data from the USB disk.
However, I cannot seem to copy/paste anything from either SD or internal memory into the USB hard disk. I copy a file, navigate to the hard disk folder, and then click Editor-Paste as usual. The transfer dialog comes up but then it immediately disappears, with no error or message displayed. The file is never pasted to the disk. It's like the CrystalSky is treating my hard disk as read-only.
I already tried going into Settings-Storage and both the SD card and the USB disk were detected properly. I tried unmounting and remounting USB2 (hard disk) and that did not fix the issue - I was still unable to paste anything into the USB disk. I also rebooted the CrystalSky and that didn't help.
I can write files to this hard drive with no issues on both a Windows PC and a Chromebook so I don't think there is anything wrong with the drive itself. Does the drive need to be formatted in a certain way to be compatible with Crystalsky? Next I am going to try copying to a USB flash drive and see if that works, but either way I still need to fix this hard drive issue so I can back up my SD cards on the go. Please advise.
